Depressing news
Old Jun 29, 2005 | 03:40 PM
gruntwannabe's Avatar
gruntwannabe
Depressing news
I was talking to a coworker of mine at the auto body place I work at.
He said that getting a lift is a bad idea. That it wears down everything faster and it'll do more bad than good.
I've wanted a lifted truck for a while but if it's gonna damage my truck, then I might reconsider.
Is this true?
Old Jun 29, 2005 | 03:42 PM
Mil1ion's Avatar
Mil1ion
From what I have seen , yes, It's what happens.
Old Jun 29, 2005 | 03:43 PM
ford390gashog's Avatar
ford390gashog
yes it will happen. no vehicle was ever made for a lift to be installed and will cause excessive wear.
Old Jun 29, 2005 | 03:50 PM
77mudder's Avatar
77mudder
It's true, But you only have one chance to do what you want. You can get a new truck or fix the parts that break, when your gone your gone no second chance.
Old Jun 29, 2005 | 04:00 PM
gruntwannabe
1. Is there any way to prevent this?
2. What are the main parts that get damaged
3. How long does it take for the parts to get worn out?
Old Jun 29, 2005 | 04:14 PM
Tyqmonn's Avatar
Tyqmonn
My F100 4x4 has had a 6" lift for about 12 years now and I haven't had any problems with things wearing out. As long as you get your angles right (steering / driveshaft & u-joint) you shouldn't have any problems. Also it handles better now with 35 x 12.50 Mud Terrains than when I drove it home from the dealer brand new!!!
Old Jun 29, 2005 | 05:38 PM
bigf150's Avatar
bigf150
The biggest problem is driveline angles and destroying u joints. Most lift companys already have this considered and usually if you get a whole kit it comes with all the parts to fix your driveline angles and steering angles. Ujoints are wearable items. Its only time before they go bad just with a lift they are known to go bad in less time. I hope this helped
Old Jun 29, 2005 | 07:41 PM
teds74ford's Avatar
teds74ford
Also, on an old truck such as this, some of the stuff might already be bad. This being said, it might exagerate some problems, but I have had a couple of lifted trucks, various models, and it wasn't THAT much of a problem. Like previously said, only steering and u-joints, and those may be bad anyway on an old truck.
Old Jun 29, 2005 | 07:45 PM
ivanribic's Avatar
ivanribic
Pay special attention to wheel bearings if you run a larger tire. More rotating weight and wider tires put more stress on the wheel bearings. This isn't to say they'll be burning up at an astronomical rate but you want to make sure they're in good shape to start with. If a lift is done properly and the truck is maintaned you shouldn't have any unusual problems with it.
Old Jun 29, 2005 | 11:05 PM
bigf150's Avatar
bigf150
Yes also a good point if you run larger tires check the bearings and ball joints every now and then. If the ball joints wear out and you dont take care of them that could lead to more expensive problems. Belive me i found out the hard way.
Old Jun 29, 2005 | 11:46 PM
ivanribic's Avatar
ivanribic
You mean like getting fillings replaced?
Old Jul 26, 2005 | 03:48 AM
gingerbreadmaniac's Avatar
gingerbreadmaniac
ball joints replacement, whats this "adjusting sleeve" 77.5 f250 4x4 (dana44)
both upper ball joints have kicked the bucket so I got new upper and lower "moog" ball joints on the bench.
im looking at em here and reading the directions and i see a "adjusting sleeve" with the uppers. it screws into the diff side of the steering nuckle. its the taper shim sorta thing that the upper sits in. No spanner wrench i have ever scene will get the old one out and new one in.
Do I need to replace this ? or can i keep the old one in there?
-gbm-
Old Jul 26, 2005 | 03:49 AM
gingerbreadmaniac
-gbm-
Old Jul 26, 2005 | 03:52 AM
gingerbreadmaniac
Im sorry.
its bad enough hitting the reply button instead of the new thread button but twice in a row?
-gbm- <-------------
Old Jul 26, 2005 | 11:29 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
I don't know, man, my '74 highboy had wheel bearings in the rear that were closing in on 300K miles and still looked almost brand-new. The fronts too...
My highboy had 33" tires on it, but wasn't lifted because it didn't need to be.
However, I saw plenty of "normal" F250/F350's, with the SAME running gear, so the "lift" in my highboy didn't do anything to deteriorate anything quicker.
I say, lift it, but check all the suspension bushings, tie-rods, steering box, leaf-spring bushings, everything. And when you do lift it, make sure driveshaft angles are correct, or at least, get CV-joints (double u-joints) put on one end of each driveshaft, closest to the differential, that will get rid of any vibration (or is it supposed to be closest to the transfer case?)
art k.
