300 head swap?
Old Jun 29, 2005 | 01:11 PM
jgetti's Avatar
jgetti
300 head swap?
All,
I have an 80 F-150 with a 300 that I'm going to rebuild. Does anyone know if I can use one of the newer heart-shaped combustion chamber cylinder heads? If not, why? If so, any years/models inparticular that will work?
Old Jun 30, 2005 | 03:17 AM
desperado_18_2000's Avatar
desperado_18_2000
The newer EFI heart chamber heads will bolt to the 300 block, and all your current intake/exhaust should bolt to them, with maybe a slight modification. As for the head itself not working, there isn't a possibility of that, you will just have to tinker with your timing a little, as this head does have a fast-burn design thats more beneficial with EFI. As for years, anything should swap right on, as the 300 block to head mating surfaces never changed.
Good luck!
Old Jun 30, 2005 | 08:54 AM
jgetti's Avatar
jgetti
Thanks! That's what I needed to know. I'm very familiar with the fast-burn combustion chamber and that is in fact my intent with the head swap. I appreciate the help!
