help
Old Jun 29, 2005 | 12:08 PM
00hotvette's Avatar
00hotvette
help
Doe's anyone know how to remove the trim peice in front of the cd player.I would like to remove my head unit.Any help would be great.
Thanks Shawn
Old Jun 29, 2005 | 12:28 PM
Dazz's Avatar
Dazz
Thanks Shawn
Pull the cup holder tray out approx 1½ inches so that your left and right index finger fits as much as possible under the bottom left and right corner of the Stereo/CD player trim. It takes a very firm pull toward you, away from the Stereo/CD player to get the little tabs to pull away from the holes they fit in under the trim.
Put a towel on the dash, adjacent to the stereo/cd player, on the passenger side as scratch protection if you proceed further.
Old Jun 29, 2005 | 05:58 PM
00hotvette's Avatar
00hotvette
thanks will try.
Old Jun 29, 2005 | 06:00 PM
dgoetz's Avatar
dgoetz
I also used a screw driver (with a towel under it) carefully to help get a little more leverage. There are 6 clips holding it in.
Old Jun 29, 2005 | 06:21 PM
ChrisAdams's Avatar
ChrisAdams
8 white clips, very firm, very sharp. They like to stay in the dash the first time you yank it.
Pull them out, carefully, they bite, and put them in the surround before putting it back on. After the first time, none of my clips have stayed in the dash.
If you have the seatbelt warning light it has a very short cable. Some people disconnect the harness to it. Others disconnect the lighter and A/C harness. I never have bothered, as with a towel to rest those sharp clips on, there is enough room to get both hands and a double in in the hole.
Chris
Old Jun 29, 2005 | 07:32 PM
00hotvette's Avatar
00hotvette
yep they were hard to pull off but I did it with thanks to you guys.
Wow there is a lot of room once you pull out the raido.
Ok here is another question. I bought a shaker 500 6 pack changer will it work in the F150 also I noticed a empty plug is this the wiring for the factory sub?.
