Blowing fuel pump fuse?
I have a’95 Bronco 5.8l auto 125k miles, hoped in it to go to the parts store, got about 4 blocks away from the house when it died. Got it back home start checking things find no fuel pressure or fuel pump noise when key is first turned on, check all fuses(#’s 9 & 16) and swap #1 & #2 relays still nothing. Must be the fuel pump, get a replacement swap them out. Test old pump on battery nothing (good I made the right diagnosis). Go to start the truck, fires right up then dies, start checking every thing agin find #16 fuse is blown. Jumper direct from the battery to the fuel pump with very small gage wire (18 or 20) truck runs great for 20 min. Go back to parts store and buy 2 fuses a 20amp and a 30amp. Install 20amp truck starts then dies fuse blown, same with the 30amp. What is happing is it a defective pump? Am I missing some thing?
Also there are three metal lines that go in to the plastic pump housing one, feed one return, & and one that 90s over and stops in the tank. The third line presses into a metal retainer how do you separate the line from the retainer? I hade to destroy the plastic housing on the original.
WhiteBeast-05-powers
1997-2006 Expedition & Navigator
22
02-01-2022 10:14 PM
MD79TA
02-02-2015 12:44 PM
redman84
34
11-21-2011 04:40 PM
CRAZYC123
08-26-2011 10:02 PM
