Best way to clean windshield grim?
Originally Posted by Ruckus
I am curious what the advantage is in using "Invisible Glass"? Thanks for any explanations or suggestions.
Google invisible glass, lots of propaganda.
It does work though. Cheap at WallyWorld, and one container can do a lot of windows.
Chris
I too concur with the Invisible Glass. Little more work than just slapping on windex and wiping, but well worth it. I use a clean cloth applicator pad (square wax pad) to apply it and then wipe with crumpled newspaper. AWESOME.
Anything that can leave the windshield of my wife's accord (Honda has the worst hazing of windshields from dash "burn off", or whatever you call it) streakless and spotless is okay in my book.
You're all right that IG and spraw a way works great......
here's the formula....
Buy a plastic spray bottle
fill 3/4 with denatured alcohol
fill the other 1/4 with a 50/50 mix of white vinegar and water
add one drop of liquid dish soap.
an incredible cleaner for about 35 cents per bottle
Originally Posted by WheelMA1
Ive always just used windex and a soft cloth.
Then I tried this IG stuff and it's good. Better than the Windex.
I've also used denatured alcohol, (used to buy it by the gallon can when working on computers) and it tends to dry too fast, or eat things on the dash.
Alcohol is VERY chemically active. I can show you laptops that have had the finish removed because they were cleaned with denatured alcohol.
Mixing it with water kinda defeats it's purpose, but one of these days I will try that mix, why not?
I havn't used half the three dollar spray can yet, after months though.
Chris
