Wimpy transmission?
Old Jun 29, 1999 | 11:48 PM
Lando
Guest
Posts: n/a
Wimpy transmission?
My '93 F150 has the Mazda 5 speed transmission and the 8.8" rear axle (3800 lb rating on the axle).
Can anyone tell me what the weak links are concerning this transmission, what the maximum safe towing limit is and if a manual transmission oil cooler could be added? If so, how much would it help? I have 3.55 gears (axle code 19); according to one source that means I can tow 3600 lbs. I am mainly wondering how much of a problem the transmission will be.
Old Jul 4, 1999 | 11:00 PM
Lando
Guest
Posts: n/a
Wimpy transmission?
In case anyone is interested, someone on another chat board said that the transmission is tough enough, it is the clutch that slips under high loads.
I realize not all questions get answers; some things aren't known.
Still I am surprised that this question didn't generate any comments, since other messages suggest that this is a fairly common question among F150 owners.
Old Jul 5, 1999 | 01:04 AM
Banzai's Avatar
Banzai
Wimpy transmission?
in reply, the trany seems to be fairly strong. I am running a 302 and the 5 speed, my problem is that I love the low end but want to be running less RPMs on the high end. Currently I am running 3300 at 75MPH, this seems to be hard on the engine. I would like to take the 5th gear and change it to lower the RPMs at this speed. Is there somebody out there that can do this for me. If so how much.
Old Jul 5, 1999 | 10:23 PM
mvanaman's Avatar
mvanaman
Wimpy transmission?
I had this trans, in my 88 f 150, did a lot of towing-cars, boats etc. and had no failures. The truck was totaled at 90k by an 87 year old running a stop sign. Oops, I did have to replace the rubber plugs in the top of the trans, they started leaking at about 60,000 miles.
Mick
Old Jul 6, 1999 | 07:28 AM
Deen Hylton
Guest
Posts: n/a
Wimpy transmission?
DrQuietus
All Things Towing
Sep 30, 2016 09:42 PM
Michael Hopton
May 23, 2012 09:06 PM
David85
1983 - 2012 Ranger & B-Series
22
May 18, 2008 03:17 PM
8NRay
Sep 27, 2004 12:35 PM
brents
1997 - 2003 F150
May 18, 2001 10:28 PM
