DIY Spray on liner?
I was wondering if anyone had any experience with these and, assuming proper prep work and application, how that would compare to a professional liner such as rhino or such.
I've always steered away from the roller kits figuring it would be difficult to sufficiently coat all areas especially corners. But to spray it in looks like it might be a decent money saver....
http://Spraymaxliners.com
Thanks,
Rex
The one gallon DIY kits, which they say is enough for a short bed truck, is about $90. I'm a LINE-X dealer, we spray about 4.5 gallons in a short bed truck. So, 4.5 gallons of a DIY kit would be $405.
Thanks,
Rex
I think I'll give up on this idea for my truck, but I might have to think about it for a flooring material in the boat....
All tires are made of rubber, therefore all tires are all about the same, right? No, not so. Tires can have very different physical propeties. Bedliners are the same way.
Like tires are made of rubber, bedliners can be of 3 different basic components:
1. 100% polyurethane
2. 100% polyurea
3. Blend of polyurethane and polyurea
Both polyurethane and polyurea give the bedliner desirable properties. For example, polyurethane has 2 to 3 times the abrasion resistance of polyurea. Polyurea, gives the liner a higher temperature tolerance and tear strength. The best liners contain a mix of both polyurethane and polyurea. Polyurethane is inexpensive, polyurea is more expensive.
I've already covered one-part vs. two-part polys.
Aliphatic vs. Aromatic: This has to do with the molecular structure of the hydrocarbons in the poly resin. Aliphatic poly is more UV resistant than aromatic poly, but aliphatic poly is not UV proof. There are a few bedliner brands that advertise no fading because they use aliphatic poly. However, they DO fade, I've seen some of them myself. I think the problem is that the other chemicals in the resin which are not UV resistant render the bedliner UV unstable, hence, they fade anyway.
You can buy Goodyear tires and be comfortable that the quality is good or you can spend less money and buy Brand X from a country you can't pronounce. Bedliners are the same way. There are hundreds of these little bedliner companies that buy their product from a third party that may be in that same country as Brand X. LINE-X, for example, uses BASF as their only source of raw materials. You can be comfortable that any bedliner brand that buys from BASF, Dow Chemical, etc., is providing the best there is.
Brand Examples:
Mix of polyurea and polyurethane (two-part): LINE-X, Vortex, Ameraguard.
100% polyurethane (two-part): Rhino, Toff.
100% polyurethane (one-part): Superliner, Speedliner, Herculiner, Durabak, Duplicolor.
100% polyurea: Xtreme Liner, Combat.
Let me know if you have any questions.
they all offer a life-time warranty vs the DIY stuff, I am not a fan of, used it myself on a Toyota tacoma bed, turned out terrible.
Rex
Thanks for the Encyclopedia of Information.. you do a very good job of cutting through the crap. I have one question.
You mentioned that you have seen some of the liners that have begun to fade. How old do you think some of those liners were? Or to put it another way, What do you think the reasonable life expectenancy (sp?) is on these products?
I ask because I have a 97 with a badly abused bed. (read previous owner ran a steel shop) I am not interested in spending a fortune, I really just want something that will clean up the look from 10 or 15 feet away, and will last 2-3 years (which is how long I figure I will keep the truck).
If this was a New truck, that I would keep for 10+yrs. I would happily got to a Pro and pay to have the top quality stuff installed properly and take the benefit of the warranties etc...
Thanks,
MK
Calling some dealers next week to get info on getting it done by an expert.
1. Fading: All brands of bedliners fade at least some unless you take certain steps (see below). The bedliner brands that fade the fastest will start to fade after about 6 months in the sun. Here's a pic of flares and rockers sprayed in a color match that has faded. This particular company states that their liners don't lose color.
As far as LINE-X, you have 4 options to keep the liner always looking brand new:
1. Apply Just Once (www.justonce.com) on the liner a several times a year. Just Once is a UV protectorant (like Armorall) that is not oil or silicone based so it's not slippery. You can use Just Once on any brand of bedliner.
2. Have your LINE-X dealer apply Ultra Shield. Ultra Shield is a one-time applied UV topcoat. It will give the liner a satin finish. With Ultra Shield, the liner will not "sparkle" as much as a new LINE-X liner with nothing on it. Ultra Shield works very well. However, it may occasionally show scratches. Not that the liner or topcoat is damaged, but it just shows scratches. You can eliminate the scratches with Just Once or a like product. It's worth the price.
3. Have your LINE-X dealer apply (black) Dupont Nason paint. Nason is an automotive paint (with a urethane base) and is what most LINE-X dealers use when color matching a liner. It is very durable and works extremely well when applied right after the bedliner is sprayed in. It will give the liner a glossy finish. Typically, the liner will be a darker black than the Ultra Shield. The cost of applying Nason should be about the same as applying Ultra Shield.
4. Have your LINE-X dealer apply LINE-X Xtra. Xtra is a brand new product and not all dealers are spraying it yet. Line-X-Xtra is the first product offering resulting from a partnership between Line-X and DuPont Performance Coatings. The spray-on high performance bedliner is a “new benchmark” in exclusive composite coatings, as it combines the world renown strengths of DuPont™ Urethane Technology and DuPont™ KEVLAR®. Line-X-Xtra features include improved appearance, improved resistance to ultraviolet light and excellent adhesion to the bedliner. In addition, Line-X-Xtra is specially formulated with DuPont™ KEVLAR® micro pulp fiber.
2. Restoring a nasty liner:
If the liner in generally in good shape but has lost a little color, scrub the liner with water and a stiff brush, let it dry, and then apply Just Once.
If the liner is generally in good shape but has faded really bad, clean it as indicated above and find a LINE-X dealer that will spray Nason on it. I had a customer that came in with a used white truck that he just purchased. This white truck had a green bedliner in it and he hated it. He really didn't want to pay big bucks to have it stripped out and resprayed. I painted it with Nason and charged him $100. He was so thrilled, he paid me $125. It looked brand new. Now, the Nason/bedliner combo works best as far as durability when Nason is sprayed right after the bedliner is sprayed in, but its still durable and this situation was just right for the customer.
If the bedliner is torn up as well as faded, then I don't really have a good solution for you. If you take it to a dealer to have it topcoated with more bedliner product, it may or may not stick. It's a risky situation and you may be throwing away your $.
L o n g post...let me know if you have any questions.
