stuck?
Old Jun 27, 2005 | 03:38 AM
texancrush08's Avatar
texancrush08
stuck?
i was recently replacing my alternator in my 77 f-150 351m, when the top alternator bolt going to the head broke off inside. i've tried drilling for the past few days and have barely gone a 1/4 in. is there a different place to mount the alternator or a bracket that mounts lower?
Old Jun 27, 2005 | 06:51 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jun 27, 2005 | 07:11 AM
ranger429's Avatar
ranger429
Try a hardened steel drill bit. That piece should come out pretty easy as there is no "pressure" holding it in. Drill out the center and use an easy out.
Old Jun 27, 2005 | 10:02 AM
T18skyguy's Avatar
T18skyguy
Thumbs up Torch blasting broken bolts
If you cant get it out with the usual methods, call some of your local exhaust shops and ask if they can remove it with a welding torch. They can actually blast it out without hurting the threads cause there is a thermal break between the bolt and the block. This is how some shops remove broken exhaust studs from our Fords. Sounds scarry, but works great.
Old Jun 27, 2005 | 10:27 AM
deisele75's Avatar
deisele75
have you tried an Easy Out?
Old Jun 27, 2005 | 11:31 AM
SwOkcOffRoader's Avatar
SwOkcOffRoader
sounds like your drill bits are dull......i had that happen to me once, but i got lucky, about a 1/4 inch in the bit grabbed the bolt and started turning it in, so i put the drill in reverse and the bolt backed right out, so i didnt even need the easy out i just bought beforehand....if your a 1/4 inch in you should be able to get an easy out to grab it..........
Old Jun 27, 2005 | 11:48 AM
Mil1ion's Avatar
Mil1ion
Yes, there is lower bracketry for alt's available.
You should find one in a wrecker.
