Click on User CP at the upper left of the screen, and then look at the list there on the left and click on "Edit Gallery". There are instructions that will guide you through the process of setting up your gallery and uploading pics from your harddrive. They pefer the you only use Ford truck related pics, except for your Avatar and such like that can be kept in a hidden gallery. There are instructions there on how to do that as well. -TD
On Edit: Okay, I see that you've already set up your gallery. So go into your user CP and click on "Edit Gallery', then scroll down to "Add photo(s) to album".
Click on "Browse" and it will open a "File Upload" window that will let you access the pics on your Harddrive, usually starting from your desktop. You can navigate around on your computer through that upload window and choose the folder you want to upload a pic from. When you have found the one(s) you want just click on one and it will put it into the little upload window, then just click on "upload", then sit back and wait...and wait...be patient, it's coming...ah, there it is!
Now, just add your text and your ready to go. (Pay attention to the image file size and image type. Images of the wrong file type or too large a size will not upload, and the bigger the image the longer it takes. Good luck, it ain't too hard, you'll get the hang of it! -TD
