Bronco II Ford Bronco II
B2 Brake Problems
Old Jun 26, 2005 | 01:52 PM
manasota's Avatar
manasota
B2 Brake Problems
My brakes are acting up. When I apply the brakes it sounds like a blast of air coming from the pedal and the motor revs slightly. No visible leaks anywhere.
What do you think? Brake booster, master cylinder, vacuum line?
Old Jun 26, 2005 | 03:58 PM
plilikoi's Avatar
plilikoi
Do you have cruise control? It sounds as though the cruise control servo is dumping air pressure, but the system isn't getting the signal to stop adding more air. Check your brake lights to make sure they're working properly. The leads on the brake pedal switch tend to break internally (invisibly) due to flexing. This switch controls the cruise control and brake lights.
Old Jun 26, 2005 | 03:59 PM
Ken00's Avatar
Ken00
Sounds like a vacuum leak in the power brakes. Disconnect and plug the hose and see if it goes away.
Old Jun 26, 2005 | 04:20 PM
manasota's Avatar
manasota
No cruise control. I don't hear any noise from around the booster/master cylinder when the brakes are applied. Only inside the vehicle.
Disconnect the hose from the booster to the motor? If it stops the hose and plug need replaced?
Old Jun 26, 2005 | 04:40 PM
Ken00's Avatar
Ken00
If you disconnect it and plug it and the noise stops I would suspect it.
Old Jul 3, 2005 | 07:16 PM
manasota's Avatar
manasota
Turned out to be a bad booster. A $70 part and it's good as new.
Old Jul 4, 2005 | 08:02 PM
Ken00's Avatar
Ken00
Glad to hear you got it fixed!!!!
