Sponsored by: Auxito
rust proofing
Old Jun 26, 2005 | 08:58 AM
lancekilgore's Avatar
lancekilgore
rust proofing
My 2000 F150 I bought recently did not come with rust proofing and had quite of bit of rust underneath. Is this normal for Ford not to rust proof the vehicles?? I went ahead and cleaned all the old rust off primed and rust proofed the underneath since I plan on keeping the truck for a while. I guess that I am used to most of the vehicles I have owned to come prerust proofed.
Lance
Old Jun 26, 2005 | 03:25 PM
bulrydr_1's Avatar
bulrydr_1
My 2000 wasn't rust proofed either... What type of coating did you use. My truck will see off road use, and I want to do what I can to protect it. Not to mention frequent trips to Wyoming in it to visit family, so I don;t want the road salt and such on the underbody...
Thanls,
Mike
Old Jun 26, 2005 | 04:42 PM
lancekilgore
most of the rust I had was along seams and behind the front tires where the rocks were kiked up from the front tires. I cleaned the whole under neath at the car was then a quick sand and a beonw rustolium primer to cover the bare metal spots. Then a coating of a rubberized undercoating. I don't plan to take it off road unless I have to but I will if needed. so I only put one coat on it if you plan to do alot of offroading with water usage I would use two coats. Usually when it comes out of the rattle can it comes out pretty thick.
Lance
