DOes anyone know anything about an Fx4 emblem that might be able to replace the ranger xlt emblem on the fender 'cause I found it for $29 at fordparts.com and I don't know if it'll fit there.
just so you know, behind the emblem on the front fender is about a 1/2 inch hole to line up the emblem. Just thought you'd like to knoe before pulling it off and putting a sticker over it.
The emblem which you are referring to is from the FX4 Expeditions........
There was a guy I knew of over on GEN EDGE (no longer exists) that used that emblem on his tailgate but as was said above if you remove your RANGER emblems there is going to be a couple of small mounting holes that will need to be filled...
