are my timing gears going?
Old Jun 25, 2005 | 08:48 PM
mnpulsar's Avatar
mnpulsar
Just bought a 88 f-150 with the inline 6. While driving home the other day she all of the sudden started clattering almost sounding like a deisel at ide. Sounded like the valve train was off. Went to check the timing for the gears by placing at TDC and looking at the dist (about 1 cyl off). The engine still runs ( I limped her home) . Has any one had the gear go only enough to make it run rough? And is there anything else I should look for before I dig into it in a couple of weeks?
Thanks
Old Jun 26, 2005 | 01:13 AM
81-F-150-Explorer's Avatar
81-F-150-Explorer
I'd check the distributor itself first, just to be safe. Make sure there isn't a lot of play in it.
Old Jun 26, 2005 | 06:55 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome mnpulsar, to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jun 28, 2005 | 09:49 PM
mnpulsar's Avatar
mnpulsar
No, the Dist has very little movement
