Sponsored by: Real Truck
bushing/grommet lube?
Old Jun 25, 2005 | 05:25 PM
tinytrixie's Avatar
tinytrixie
I had heard in the past that you can lube the rubber bushings between the body & frame, also the twin I beam grommets with brake fluid. Does anyone know what should be used?
Old Jun 25, 2005 | 05:44 PM
npccpartsman's Avatar
npccpartsman
Brake fluid will remove your paint. I'm not sure WHAT you could get to penetrate all the way into the bushings I assume you are wanting to prevent squeaks? Liquid silicone will work. Also--Wurth, inc. makes a product called rubbercare that's wonderful for preserving and lubricating rubber--especially door seals, etc--but I've only seen it available at bodyshops or professional shops.
Old Jun 25, 2005 | 10:14 PM
Chris_in_Texas's Avatar
Chris_in_Texas
You can get the Wurth here:
http://www.autopia-carcare.com/wus-890110.html
