Engine tick
Old Jun 25, 2005 | 09:47 AM
discmasher's Avatar
discmasher
Engine tick
Hi-
I have an 88 f150 with a 302 that is ticking. It ticks when it is cold and also while accelerating or under load. It has been suggested that the exhaust manifold gasket needs to be replaced. If so, any ideas on the difficulty of replacing these? Are there any gaskets that would be better than the OE style replacements? Thanks.
Mitch
Old Jun 25, 2005 | 09:51 AM
clark714x4's Avatar
clark714x4
check you timing first!
Old Jun 25, 2005 | 09:54 AM
FghtinIrshNvrDie's Avatar
FghtinIrshNvrDie
definately check the timing first.... buuuut
in most cases, it's not the gasket that needs replacing. The manifold actually cracks, and that's what's ticking. Run a search about cracked exhuast manifolds and see if that helps, if not, keep posting.
Ryan
Old Jun 25, 2005 | 11:57 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome Mitch, to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jun 27, 2005 | 09:30 AM
discmasher's Avatar
discmasher
Thumbs up
Thanks for the help. They were cracked.
