high oil pressure
Old Jun 24, 2005 | 08:16 PM
SasquatchF-250's Avatar
SasquatchF-250
high oil pressure
I just got my 1977 f-250 started after about 9 months of being proclaimed dead. Unfortunatly my oil pressure gage reads that it is running at a higher pressure than normal. What should i do? what could be wrong?
thanks
Old Jun 24, 2005 | 08:42 PM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
Well after sittin for 9 months..I would change the Oil to see were your really at....I think I wouldrun a detergent Oil thru it for about a week or so..drain it and go with a new filter and fresh Oil an see were your at..
And take it from there...and it might be you just dont remember exactly where the gage sat at before?
Russ
Old Jun 24, 2005 | 08:51 PM
ford390gashog's Avatar
ford390gashog
i would do a oil change and use a high detergent oil in that engine, if you are not already.just use a good filter and a diesel rated oil.
Old Jun 24, 2005 | 08:53 PM
hiball3985's Avatar
hiball3985
is it high all the time, after the engine reaches temp for a while? mine shows 80 when you first fire it up and will stay that way for quite a while, a big block has alot of iron the heat up, after its good and hot its 30 at idle and 50 driving and thats with a 140,000 miles on it
Old Jun 25, 2005 | 12:55 AM
plowpusher's Avatar
plowpusher
get a mechanical gauge check it for real
Old Jun 25, 2005 | 03:18 AM
Hypoid's Avatar
Hypoid
thanks
No numbers? Are you reading the stock guage in the instrument cluster? The sender could be going South, especially if it was installed in '77. Oxidation on the wire connectors could give a false read also.
If you don't already have an aftermarket gauge installed, it's time. Post some numbers and we'll tell you if it's anything to worry about.
Old Jun 25, 2005 | 09:32 AM
SasquatchF-250
Thanks for the input i will try detergent oil...any particular brand good? The truck does have recent gages...with in the past 4 years...from what i can remember it idled at about 40 but now its about 70
Old Jun 25, 2005 | 09:43 AM
hiball3985's Avatar
hiball3985
try a new sending unit
Old Jun 26, 2005 | 10:28 PM
1bigsteve's Avatar
1bigsteve
Talking
I had the opposite problem with my gauge reading no oil pressure while I was driving. After pulling over and recovering from a major heart attack I found that oil had contaminated the electrical contacts on the gauge (dirt and corrosion can do the same thing). I cleaned it up and it worked fine. Away I went. Other than that it could also be a bad gauge. When in doubt, throw it out.
I believe that any truck that has been sitting idle for more than three months should have it's oil and filter replaced before start-up. It is cheap insurance. When I need to clean sludge out of my engines I put in a quart of Gunk's engine cleaner and follow the directions. It gets the gook out of the oil galleries, rocker arm shafts, crank journals, etc.
-1bigsteve (o:
Old Jun 26, 2005 | 11:39 PM
ford390gashog
i would use rotella t or delo only about 7.00 a gallon.
