Bronco II Ford Bronco II
removeable side glass
Old Jun 24, 2005 | 12:11 AM
SEDUCED's Avatar
SEDUCED
i'm looking to make my side windows removeable. i'm wanting to use a resin like the Lexan resin that the drink containers are made of, but dont know if that will meet the DOT requirements, has anyone heard of anyone besides Nascar using this as an automibile window?
Old Jun 24, 2005 | 03:24 PM
80`F-150's Avatar
80`F-150
As was thinking the same but not putting plastice ones in, just takeing the glass ones out for summer. so I will be watching the theard closely
Old Jun 28, 2005 | 10:41 AM
SEDUCED's Avatar
SEDUCED
well i've been doing alot of research in this project, and i think what i'm gonna do now, is take my glass to a shop equipped to drill it, and maybe just bolt the windows to the body, if it doesnt look like that will work, i'm thinkin that i mighttry and make a bracket that i can use to hold the windows to the body. (i'm doubting that i can keep the windows waterproof if they are just bolted to the body tho)
Old Jun 28, 2005 | 06:37 PM
884x4broncoII's Avatar
884x4broncoII
here is my idea, get them drilled glue some large metal washers to the outside of the holes, to keep from cracking the glass, then get some weather strippping like what you use for car doors put that in the window seam, so when you put the windows in and tighen them down they will be air/watter tight
Old Jun 29, 2005 | 02:14 PM
zr440man's Avatar
zr440man
I'm not 100% sure here, but I believe that those windows are the tempered glass, and you can drill holes after it's been tempered...I think I'll shatter. I busted the extended cab window out of one of my Rangers that had the tip out style ones. I found a non-tip out used glass, but was told you couldn't drill holes in it... Like I said, not 100% sure, but might have to check into it....
david.brady
Jan 18, 2015 07:46 PM
jniolon
15
Aug 31, 2011 10:49 PM
DieselScoff
Feb 20, 2011 05:31 PM
midmoford
Oct 4, 2008 10:47 AM
Goose_52
Paint & Bodywork
Aug 10, 2008 12:16 PM
