Anti-Theft sys acting up
Old Jun 22, 2005 | 08:25 PM
valleyd01's Avatar
valleyd01
I have 98 Navigator with 50K . My wife called me at work and said the horn was chirping a couple of times every minute or so for the past 30 minutes while it was parked in the garage. I disconnected the negative battery cable for a few minutes and everything seems to be working correct now. I also checked the battery and alternator and the voltage checks out OK. I guess I will find out in the next couple of days if this was a permanent fix. I was wondering if a bad key fob would cause this problem. I hear that when the battery is disconnected and connected back that a GEM (Generic Electronic Module) is reset, not sure what it is or where it is located. I heard these are susceptible to moisture from a leaky windshield in the earlier Nav/Expy.
