00 expy
Old Jun 22, 2005 | 06:50 PM
copicatt's Avatar
copicatt
Question 00 expy
recently purchased a 00 EB. it has 75k on it. I have a few issues that the dealership is taking a look at now. first: when putting into reverse, there is a shudder, sometimes slight, sometimes very noticeable. I was finally able to get the tech to notice it and he said he would have to research it. that was last week. they have it again today to follow up. i'll be contacting them in the morning. it seems to be worse when facing uphill. i don't really notice it when shifting into other gears. Next: there is a knock when driving over speed bumps or even my back yard, seems to be coming from the rear, the spare seems to be tight. Last: It has a vibration, mostly from 10-45 mph. feel it in the seats, and floor. I read on a previous post about the driveshaft. does it tend to have problems on this model? Sorry, so many questions, but i'm calling them in the morning, and i need some ammo. I'm trying not to get discouraged. i love this thing, but i hope these can all be resoved .
Old Jun 23, 2005 | 06:38 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome copicatt, to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jun 23, 2005 | 10:23 AM
Hoosierdaddy's Avatar
Hoosierdaddy
Your vibration is most likely the driveshaft or a bad u joint. The noises when shifting to reverse could easily be the same thing or in the rear end. My first guess would be a Ujoint. As for the rattle in the back-check your shocks. My 99 Expy had the same rattle that I chased for a year before replacing my shocks. After replacement, everything was quiet. It ended upthat my shock bushings where worn inside. They felt tight and looked ok when bolted up, but where worn enough inside to have slop when truck moved. You may need shocks.
Hope this helps.
Old Jun 23, 2005 | 02:39 PM
buzzard's Avatar
buzzard
Agreed, check your shocks...actually replace your shocks if they are original with 75K miles.
Most vibrations are tire/wheel related. Check pressure, roundness, balance, etc.
Old Jun 24, 2005 | 05:12 AM
1owner's Avatar
1owner
My vibration at 76000 miles turned out to be the ball joints. Three of the four were bad. You might have them looked at.
Old Jun 24, 2005 | 01:55 PM
buju70's Avatar
buju70
I had a similar vibration in my 2000 as well, I had the transmission and more importanlty the Transfer case fluid replaced, and the problem was fixed. Also had a problem in the year end which was fixed by lubricating the control arms in the rear.
Old Jun 24, 2005 | 05:10 PM
copicatt's Avatar
copicatt
well, the dealership called today and needed authorization to tear down the tranny. i said go ahead as long as its covered. they still haven't had a chance to look at the other problems yet. i'm kindly discouraged. we'll see. thanks for the replys guys. i'll let you know what happens.
Old Jun 24, 2005 | 10:35 PM
copicatt's Avatar
copicatt
well, i decided to run a carfax on this vehicle. a little late now i know. turns it it was a fleet vehicle and has had 4 owners. the dealership i bought from evidently acquired this expy in feb 15. it was evidently sold to someone in this area on 4-01-05. but wait a minute, i bought this on 6-11-05. for some reason this other buyer returned it. i am scared. i set up an appt for service on 6-13-05. it has been at the dealership since tuesday for these problems. they say its gonna take a few days. i'm gettin steamed! they probably knew that there was a problem with this vehicle. it may not be anything major. waht would you guys do? storm in tomorrow and demand a replacement? wait a few days, see what they find? am i covered legally on this? I only have a 30 day warranty, that's almost half gone. any suggestions.
Old Jun 26, 2005 | 12:51 AM
dking69's Avatar
dking69
My 2000 4x4 EB EXPY had just expired the warranty when the tranny started to make a grinding/shuttering when you put it in reverse or was taking off from a dead stop.
It was very hard to pinpoint the problem. Sounded like the rear diff. or front transfer case? Took it to a tranny shop, $1400.00 out of my pocket later, the Planetery Gear was bad. This gear is used for reverse and slow forward motion.
There is no drain plug on the transmission case. If you remove the bottom cover and have metal filings, you found the problem.
Hope this does not happen to you.
KingSwing
Old Jun 26, 2005 | 12:44 PM
copicatt's Avatar
copicatt
talked to the shop yesterday, they said a spring was broken in the tranny. it should be in on tuesday. hope this helps. oh, and i talked to the previous purchaser, and they said they traded in because of gas mileage, they didn't notice any problem.
RANGER589
Electrical Systems/Wiring
Jun 25, 2014 09:09 AM
RRranch
26
Sep 18, 2011 10:21 PM
dave boley
47
Feb 23, 2009 07:16 AM
orion39
Dec 23, 2008 06:33 PM
msova
1983 - 2012 Ranger & B-Series
Mar 29, 2004 03:38 PM
