Oil Filter hoses
Old Jun 22, 2005 | 12:22 AM
Freak4Ford's Avatar
Freak4Ford
Oil Filter hoses
I have a 1998 EX XLT 4.6. The truck has 115000 miles. I was changing the oil the other day and noticed a small leak comimg from the hoses leading to the oil filter. I was wondering if anyone else noticed this problem and was if difficult to repair?
Old Jun 22, 2005 | 12:26 AM
ford390gashog's Avatar
ford390gashog
what hoses? do you have a after market oil filter adapter?
Old Jun 22, 2005 | 08:27 AM
bully 515's Avatar
bully 515
i noticed one of mine leaking also, same year and motor size. never fixed it, still leaking... i beleive they are oil pressure hoses.
Old Jun 22, 2005 | 12:29 PM
Luzer27's Avatar
Luzer27
I had to replace one of mine it was the hose after the filter back to the block. It was 40 bucks. In hindsight I should have just made the hose and used aeroquip or bark fittings and saved a little. Ford390gashog, he is refering to the hoses that go the the remote oil filter under the front bumper. This was an option in 97 through at least 99 since mine has it. Not sure when they stopped it. On the 4x4 it looks like you would make a mess trying to change it if it were on the block.
-Dave
Old Jun 22, 2005 | 04:55 PM
great white's Avatar
great white
Same story here. On my 98 Expy (140K), it appears the leak is coming from the "crimps" where the hose connects to the aluminum base behind the filter. Called the dealership back in the spring, to replace the asy, oil filter base back to the block $165.00 (just the part only). I added a couple of hose clamps for insurance and keeping an eye on it.
Old Jun 22, 2005 | 10:57 PM
Freak4Ford's Avatar
Freak4Ford
Great white,Did you replace the hose assembly with the part from the dealer or did you repair it with the hose clamps you mentioned?
Old Jun 23, 2005 | 08:54 AM
great white
I did not replace the asy. As for the hose clamps, I installed them over the existing "crimps" thinking I could add additional pressure in an effort to stop the leaking, no luck. Leaks just enough to get the hoses wet, but not enough to actually drip in the driveway. I think the only way is to replace the hose asy, if you can get over the cost.
