Pcv
Old Jun 21, 2005 | 06:26 PM
RUFUS2.9's Avatar
RUFUS2.9
Pcv
I replaced the PCV and the engine idle went from 850 to 1200-1250 and rough.Adjusted the idle back to 850 and seems a little rougher than before replacing PCV. Anything I should be checking or is this norm,PCV didn't make any noise when I shook it.Rechecked timing and it's good.
'88 2.9 165000 on it.
Trying to get parts store to check codes w/o light on ,having no luck.Been told too old to check to I would but someone stole it.
Old Jun 21, 2005 | 10:05 PM
GrayRanger4x4's Avatar
GrayRanger4x4
Sounds like the rubber hose is cracked or broke.The one from the PVC to the upper intake and you have a vacum leak.
Old Jun 21, 2005 | 10:08 PM
RUFUS2.9's Avatar
RUFUS2.9
Thanks ,it Does Feel Very Hardened,i'll Check It In Morn.
Old Jun 22, 2005 | 10:20 AM
mrshorty's Avatar
mrshorty
Note 1) How did you adjust the idle?? Technically, the idle on the 2.9 is not supposed to be adjustable. I know you can fiddle with the throttle stop screw and get some adjustment to the idle, but the computer is supposed to control the idle via the IAC valve. One common cause of rough idle is having this valve be dirty. Wouldn't hurt to pull the valve and clean it.
Of course, any vacuum leak will screw everything up like grayranger said, so make sure there are no vacuum leaks.
Note 2). Just because it's a common mistake, not necessarily because I think it's the problem, but you checked timing with the SPOUT removed, correct?
Note 3). It seems that a lot of parts stores have no clue when it comes to the EEC-IV system. Light on, light off, brand new, no start, you can always pull codes. You might get all pass codes, but that doesn't prevent you from pulling the codes. I suggest you read through Ken00's article in his tech info post about pulling codes and do it yourself. Assuming you have a functional check engine light, all you need is a jumper wire (eg paper clip).
Old Jun 22, 2005 | 02:10 PM
RUFUS2.9's Avatar
RUFUS2.9
Set Idle Back W/stop Screw. Spout Was Disconnected Both Times,first Time Dist Was Moving On It's Own. Thursday I'll Have Someone To Copy While I Count Using The Engine Light. I Will Have To Find And Clean The Iac Valve.
Thanks
Old Jun 25, 2005 | 12:24 PM
RUFUS2.9's Avatar
RUFUS2.9
Thanks mrshorty,cleaned IAC and air intake,then I reset the comp,as per instructions I found on net,idle is now as it should be.Now if i can get someone to help w/code reading using check engine light( I've been known to stumble while chewing gum ).
Old Jun 27, 2005 | 10:42 AM
mrshorty's Avatar
mrshorty
Was Ken00's article a little too technical? I always thought it was easy enough to follow, but I can see how others might have trouble with it. Try www.troublecodes.net/Ford, or www.fordfuelinjection.com
Old Jun 27, 2005 | 12:16 PM
RUFUS2.9's Avatar
RUFUS2.9
Not too technical, just that I would like someone else to write while I count.Seems like it would be real easy to miss a blink or two doing both.
Old Jun 30, 2005 | 03:58 PM
Jharger's Avatar
Jharger
Autozone have readers for ~$30. Are there no DTC ports on these older models?
Old Jun 30, 2005 | 04:43 PM
RUFUS2.9's Avatar
RUFUS2.9
The only readers I have found for 30$ are just blinking lights. It's 148 $ for a real code reader at Advance.
Old Jun 30, 2005 | 04:49 PM
Jharger's Avatar
Jharger
That's about what i paid for my AutoXray unit. But I just got it upgraded to read OBD-II so now I have one scnner for the Explorer and Durango.
