a4ld problems
Old Jun 20, 2005 | 05:23 PM
944x4ranger's Avatar
944x4ranger
a4ld problems
hi, i'm new to the site. i have a 94 ranger 4x4 with a a4ld tranny. my problem is when the truck has been sitting for a while, it does not want to shift out of first gear. it will stay in first for about a mile, then seems to shift fine. i hope its not anything major. any help would be greatly aprecitated. thanks in advance.
Old Jun 21, 2005 | 07:45 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jun 22, 2005 | 03:03 PM
944x4ranger
no one has any ideas???
Old Jun 23, 2005 | 10:15 AM
rclarke's Avatar
rclarke
No upshift problem that goes away when warm is likely to be a sticky governor. I would check the vacumn modulator but that would be bad hot or cold.
Old Jun 27, 2005 | 11:58 AM
944x4ranger
after i replaced the modulator and that did'nt fix the problem my local ford dealer also said that it might be a sticky governor. is that a major thing to replace?? where is it and what does it do??
Old Jun 27, 2005 | 02:04 PM
rclarke's Avatar
rclarke
The governor is pretty easy, its on the output shaft inside the extension housing. With 4x4 you need to remove the transfer case first then you can reach the governor inside the transmission. 2 10mm bolts hold the governor to the governor body. If you remove it you can clean it. All there is to it is a weight, a spring, and a valve. Your concern is "what is contaminating the valve and making it stick?" If there is trash circulating with the oil it had to come from somewhere in the transmission. So, something may be failing inside the transmission. I would pull the pan to inspect the inside of the tranny. If there is anything more than a layer of fine dust in the pan you should consider an overhaul.
Old Jun 27, 2005 | 02:17 PM
944x4ranger
thanx, my local ford dealer is doing the work because i really don't have the time right now, so hopefully they will fix the problem.
Old Jul 2, 2005 | 12:23 PM
944x4ranger
well my dealer repalaced the governor and it works great!! thanks for all your help.
