Hi, my 78 truck has a 302 that recently began idling rough (park or drive) and stumbles at cruise speed. It also stalled completely once. I parked it and after only about 30 seconds, I was able to restart it and 'limp' back to the house. I replaced the fuel filter, but it didn't remedy the problem. I am not even so sure that this is a fuel problem, but maybe electrical. I hope that someone can help me here. Thanks!
I would start with a compression test and see what you got. No point looking for a simple problem if you have a major one. If these #'s are reasonable then...
air/fuel: bad pump (check pressure and volume), clogged jets, clogged pickup, vacuum leak, bad gas.
got good healthy spark and at the right time?
It may be time for a tune-up A new set of plugs/wires/cap/rotor can do wonders.
GL, welcome to FTE, check back if you need more info.
Mark
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
