Transmission bolt pattern
Old Jun 19, 2005 | 06:05 PM
jeffreysw's Avatar
jeffreysw
Is it true the 300/6 has the same transmission bolt pattern as the 302/351? If so, wouldn't the transmissions for the 302 work on the 300/6?
Old Jun 19, 2005 | 06:32 PM
DT 466Man's Avatar
DT 466Man
yes it does.
As long as you use the 300 flywheel. And a 300 Torque converter as it has a lower stall because the Peak torque is down lower than a 302-351W.
But the clutches inter change.
saltbranch
May 12, 2016 10:59 PM
300-6 AUTO TECH
Dec 17, 2006 05:13 PM
martimani85F250
Feb 2, 2006 07:25 PM
MontanaFord
18
Sep 13, 2004 12:26 AM
BlueOvalRage
Jul 7, 2002 01:28 PM
