1966 - 1977 Early Broncos
modulator valve hose routing?
Old Jun 19, 2005 | 10:58 AM
oldiron's Avatar
oldiron
Question modulator valve hose routing?
My '73 EB w/302/AT has no vacuum lines running to the modulator. So as you can imagine, it doesn't shift very well by itself ( took it out on it's maiden voyage today). Can someone tell me where to land these two lines?
Thanks
Greg
Old Jun 19, 2005 | 09:48 PM
chipper's Avatar
chipper
I just used steel brake line and bent it around to fit. Cut the brake fitting ends off. Then a small junk of rubber fuel line hose to connect to the factory vacum ends. Three years now and still works great.
Old Jun 20, 2005 | 04:36 AM
RCrawler's Avatar
RCrawler
The modulator is on the passenger side towards the rear of the case.
You will want to connect it to a manifold vacuum source.
Jason
Old Jun 20, 2005 | 10:48 AM
oldiron's Avatar
oldiron
Let me be more specific. My modulator has two vacuum fittings, one fore and one aft. What I need to know is which one is for manifold vacuum and which one goes to a ported switch..
Greg
Old Jun 20, 2005 | 10:03 PM
mauicruza's Avatar
mauicruza
The outer nipple connects to manifold vac.. the inner nipple connects to port. I've
eliminated using the inner port vacuum hose when I switched to efi. I just left the port on the modulator open and had no shifting problems yet. I did this after seeing other C4 automatics with a single port vac. modulator. I'm really not sure what that second port is for? I've also noticed 2 ports on my old distributor vac. advance in which I eliminated the inner vac. line also.
