Electrical? Brake?
Old Jun 19, 2005 | 03:33 AM
bdewbre's Avatar
bdewbre
Electrical? Brake?
I have a 2001 Expedition and the other day (not raining - so it is not the wet fusebox problem some people seem to be having) I started it and could not get it out of Park. I had someone check my brake lights (which were working) and I bypassed it by turning the ignition a little and then starting it in Neutral - just so I could get it home.
I have pulled and checked every single fuse and have also used a new relay to check to see if one of the relays went out as well. I also - just as a safety measure - replaced the brake light stop switch. The brake lights still work, but the problem persists.
ALSO, since this has happened, I have no interior lights, running board lights, power windows or windshield wipers (front and back). I am not sure if this is a feature built in by Ford saying "Don't run the car this way unless you absolutely have to" or if it is a secondary problem or if it is a symptom of the primary problem.
I have reviewed this site and others and have not found a solution past replacing the brake light stop switch.
Can anyone out there help?
Old Jun 19, 2005 | 04:15 AM
Greenscobie86's Avatar
Greenscobie86
I had the same lights and wipers problem. It turned out to be a 15 amp fuse which is 1st from the top of the fusebox* in the middle row. *(under dash fuse box)
Old Jun 19, 2005 | 07:41 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome bdewbre, to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jun 19, 2005 | 05:17 PM
triton_2002's Avatar
triton_2002
Is the brake light switch connector good? I've heard of this connection failing before.
Old Jun 19, 2005 | 05:58 PM
bdewbre's Avatar
bdewbre
Thanks for the tip ... is there a way of testing the connector to know if its good or not?
Old Jun 19, 2005 | 06:45 PM
triton_2002
From what I've seen here, one of the wires breaks off the back of the connector. You could test it with a multimeter. Hope that helps.
