need help with numbers
Old Jun 19, 2005 | 03:03 AM
f700's Avatar
f700
hi all just got back after my 391 hunt , need sum help with the numbers now to see what i have ? cast number s of the crank on the 7 weight are
C6TE6303 D it look like,s can,t turn crank yet, 3 piston rust in no bad out eight , rod numbers are C6AE-C on top of piston numbers are CAM-Z15 3H
tag on the holley number is C7TE AA 7EC the bore look,s big wait for your replys thank guys im thinking the rod are telling me its a 391 truck i will see
Old Jun 19, 2005 | 12:34 PM
FFR428's Avatar
FFR428
Needsmorecoffee.
Hmmm. Those crank numbers come up for a 361 forged crank with a 3.50 stroke not a 391. Rods are the short FE rods and good if useable. My listings show both long and short rods used in the 361. I can dig for more on this if needed. I'm not a 361 expert at all. I'll have to look up the carb unless someone knows it offhand. G.
Old Jun 21, 2005 | 03:43 AM
fordeverpower's Avatar
fordeverpower
my research leads to believe it is either a 330 or 361 based off crank and rod data.
