weird issue with factory 4-plug trailer plug
Old Jun 18, 2005 | 08:23 AM
kiosk's Avatar
kiosk
looks like the left hand turn signal is not giving out power out of the stock four-connector plug....but the left hand turn signal on the lights on the actual truck is working fine.....this is weird, any ideas???
I am going on a trip tomorrow and now run into this crap.....
Old Jun 18, 2005 | 08:53 AM
XLTinRHODY's Avatar
XLTinRHODY
Are checking the plug with a 12v tester or pluging the trailer in and get no signal at the light? I had a issue with my camper and after hours of trouble shooting it turned out to be a bad bulb socket on the camper. Good luck.
Old Jun 18, 2005 | 10:31 AM
kiosk's Avatar
kiosk
trailer lights are fine, I am testing the plug on the truck (w/o plugging to trailer) and is not putting out any voltage...just the left hand signal.
Old Jun 18, 2005 | 03:50 PM
AwesomeBullet's Avatar
AwesomeBullet
What model year? 03 and up have all the circuits individually fused, so the left hand turn signal circuit could have popped a fuse on ya. I popped a running light fuse on mine at a tournament, about 3am and pouring down rain hitching up. I accidentally left the lights in the truck on, when I hooked up the trailer plug I didn't get it just square and bridged the ground and brake pins with the ground pin on the trailer harness. Most of the trailer light fuses on the 03+ are in the fuse block behind the kick panel on the passenger side of the vehicle. On 02-, I believe most of them are still individually fused. Look in your owners manual and see if it lists left trailer turn light fuse.
Old Jun 18, 2005 | 08:01 PM
kiosk's Avatar
kiosk
it was a fuse.....i'm a retard!!! thanks!
