Dual fuel guages?
Can the instrument cluster and tank sender wiring be modified so that fuel levels from both tanks could be simultaneously displayed from the cluster?
The tanks would still be controlled by the dash switch, but each sender would always be hot and reading the level. On my 92 150, I would remove the voltmeter on the right side/top corner of my cluster display and put a new fuel gauge in its place. The gauges could be labeled "front and rear"
I think it is a cool project.
This would surely be a great look to the gauges I have already installed.
I found that on my 93 F350, both fuel senders are connected to the switch in the dash, so I simply removed those wires and attached them to an DPDT relay, and using a simple circuit the relay closes for 5 seconds, then opens for 5 seconds, then closes for 5 seconds, then opens for 5 seconds. My factory cluster can go from full tank to empty in about 2 seconds, so my fuel gauge moves back and forth indicating the two tanks.
The only thing I didn't do is have any indication as to which tank is displayed. I was thinking about putting in two small LED's into the fuel gauge, the left one being the front tank, and teh right one being the back tank, but I've never gotten around to it, so I just have a pulsating fuel gauge if the tanks have different fuel in them. I didn't bother finishing this beacuse the factory cluster is leaving soon anyway. I'm almost done making a new dashboard and fitted into that will be a digital t-bird cluster. I'll be using the fuel gauge of the t-bird cluster to indicate boost (turbocharged big-block) and on the touchscreen next to the cluster, behind the shifter, I'll have an "X" application that displays fuel from both tanks. I started breadboarding a simple A/D to "flash read" the two tanks, and provide a value 0-15 for each tank, pack them into a byte, and send to the parallel port of the computer that drives the touchscreen. I haven't finished as I have too many distractions, but it's sorta working on the workbench. The computer can read the fuel levels, and display "stuff", I just have the scaling way off. I don't recall if it's because my scaling in the software is off, or if the junkyard floats I have are not right... it's been a while since I've monkeyed with it.
I had put some expensive injector cleaner in the front tank and wanted to run it close to the bottom to get the full effect of the cleaner and ran out of fuel while the tank read a little more than 1/4 of a tank.
I had switched tanks when they were both full and the hand moved down and the engine had kept running so I thought that part of the system was fine, I go back to the front tank and ran it until it quit as mentioned above.
I figured no problem, I have electric pumps and a full tank, that is when I found out that the selector valve did not work as far as fuel delivery, but the gauge did.
I have not ran out of gas in more than 25 years, if I have to monitor both tanks to keep from doing that again I will. Keep in mind the front tank ran out reading 1/4 of a tank.
I have fixed the selector valve since then but do not trust the factory gauges no longer. Plus the look would be kind of neat to my taste anyways. That is why I had asked if there was a way to monitor both tanks at anytime, if hooking up one aftermarket gauge will achive this, that is the way I will go. So the question still is could I use a aftermarket gauge in the place of the stock gauge and switch back and forth for a true reading?
So I am guessing that the parts place will have what I need to match the spec's of the system. There is no need to know both tank levels at the same time, but I have had such a time out of the factory gauges, all of them that I am at the point of just going to all aftermarket gauges. I really dont even need both tanks, but I do want to know the true amount of fuel in either tank. I also think a home made dash that contained all the temps and such would be awsome.
When one tank is in operation, I know the pumps are off, but is it impossible to get the reading that operates the gas gauge?
Another question, I am considering making a flat bed truck and will be using a fuel cell, since the pump in the tank is low pressure can I use a conventional electric fuel pump, or do they make a fuel cell that has a pump in it already?
I like the look of some of the flat bed 4x4 trucks. I have a friend that welds and has all the metal I need to make the frame work for the truck bed. This is not my full time truck any longer and can try a few things like that.
I have the rocker switch on the left side of the dash, and the six port selector valve under the chassis.
the switch on the dash controls two things, Which Tank's fuel sender gets connected to the guel guage, and which in-tank pump gets turned on.
It is very do-able to get the two cables from the fuel senders coming into the switch, and connnect them to two seperate fuel guages.
the switch would then still be used still select which in-tank pump is turned on and therefore which tank the fuel comes from.
the only catch is that ford fuel senders are backwards from most other manufacturers. You will need to find guages that work with the ford fuel senders. you will not be able to use "off the shelf" guages from the autoparts.
a "standard" guage from the autoparts connected in our trucks would read backwards (Empty when the tank is full, and Full when the tank is empty.
check autometer guages for a compatible model.
That's such a neat idea
Definately go ahead with the LED tank indicator, and maybe instead of using just a 2 single LEDs, you could use a 7-segment LED numeric component
It'll look much cooler
I suppose you could have it toggle between displaying F for the front tank, and R for the rear or A fo r after (R looks like an A on those displays)...maybe a B for back tank, or go with a 1 and 2 type assignment.Did you simply just assemble a flasher or flip-flop circuit to trigger the relay?
I'm thinking about doing this myself, it's so easy and kind of neat
It was like... six parts.
I was gonna throw in the 555, figuring you had probably used it
I remember building tons of different flasher circuits with the 555 on breadboards for fun as a kid.
