No Reverse
Old Aug 26, 1999 | 08:49 PM
Dusie
Guest
Posts: n/a
No Reverse
I have an 89 F150 4x4 300 I6 4speed. While trying to back out of my driveway, I heard a small click and then no reverse. I have my forward gears but stick is really sloppy. Any help would be appreciated.
Old Aug 27, 1999 | 06:59 AM
dc's Avatar
dc
No Reverse
Dusie,
Although I still have reverse as well as all my other gears on my 88 F150 300 I6 w/ 5SPOD, I recently experience a problem with my gear shift lever getting "sloppy".
Somebody here posted that there exists a nylon ball on the end of the shift lever that moves the shift-shafts in and out of gear. It has a tendency to "break off" leaving just a stud to move the shift-shafts. It sounds like yours did this and is no longer meshing with the reverse gear shaft.
I purchased a replacement "lower" shift lever for mine which is now all metal. Hopefully, I will be able to replace it this weekend.
I hope this steers you in the right direction.
Old Oct 1, 1999 | 06:11 AM
Hdlinerman
Guest
Posts: n/a
No Reverse
>Dusie,
>"sloppy".
>reverse gear shaft.
>right direction.
Dusie, were you able to replace the lower shift lever yourself? I have the same problem.
Old Oct 1, 1999 | 08:45 PM
Dusie
Guest
Posts: n/a
No Reverse
It ended up being a $1.58 dowel pin that goes into the keyway at the bottom of the shift lever. The shifter was rotating preventing it from going into reverse. My local Ford garage printed out a blueprint that helped diagnose the problem. Hope this helps.
>>Dusie,
>>"sloppy".
>>reverse gear shaft.
>>right direction.
Old Oct 2, 1999 | 01:39 AM
Superdave's Avatar
Superdave
No Reverse
