Battery disconnect to reset computer - how long?
Old 06-16-2005, 09:10 PM
somegeek's Avatar
somegeek
somegeek is offline
I've read anywhere from 30 seconds to 45 minutes with the headlights on to drain the system and reset the computer to adjust more quickly to new mods added on to the truck... question is - how long do I actually need to keep my battery disco'd to reset my computer? What do the ford technicians recommend?
I unplugged my battery for about 15 minutes. The radio retained it's presets. Does this mean the system was not drained completely to reset the computer or that the radio keeps the presets regardless if it loses power?
Thanks,
somegeek
P.S. - got a 3" exhaust from end of Y pipe back with the larger magnaflow installed today - sounds damn nice. :-)
Old 06-16-2005, 09:43 PM
bobbylh's Avatar
bobbylh
bobbylh is offline
Really not sure, but I would disconnect before going to bed and reconnect in the morning. That should give it plenty of time.
Good Luck
Old 06-17-2005, 10:28 AM
ChrisAdams's Avatar
ChrisAdams
ChrisAdams is offline
Two minutes is plenty. The radio has a reserve battery on some models that holds a charge for quite awhile. I never lost my stations even on my truck after two hours. I have lost my trip odometer miles each time.
Chris
Old 06-17-2005, 03:56 PM
somegeek's Avatar
somegeek
somegeek is offline
I noticed the radio clock was reset but the presets were retained.
Thanks for the info.
Old 06-18-2005, 03:12 PM
MJEmerson's Avatar
MJEmerson
MJEmerson is offline
i thought 97 was the last year that you could reset the computer like that. will it turn off the check engine light also?
Old 06-18-2005, 04:11 PM
ChrisAdams's Avatar
ChrisAdams
No, the check light is stored. You need a code reader to clear that. Scanguage, superchips etc.
Chris
tony ciar
2009 - 2014 F150
11-17-2013 07:07 AM
nolanb
1999 to 2016 Super Duty
06-21-2010 10:53 PM
somegeek
2004 - 2008 F150
19
01-13-2006 08:41 AM
Dracoscott
Aerostar
15
11-04-2005 12:38 PM
Quick Reply: Battery disconnect to reset computer - how long?
