390 vs 400
Old Jun 16, 2005 | 06:09 PM
flcbell's Avatar
flcbell
390 vs 400
Here is the dilema. I have a 79F350 Camper Special with a dana 70 rear and a dana 60 front with a 400 currently installed.
The current engine is bad and I am going to replace. I have a perfectly good 390 with plenty of power( I checked the crank and it is a 390) and I also have a low mileage 400. The 400 has 1978 casting numbers on the heads and block. My question is, what would be the better install?
Thanks
flcbell
Old Jun 16, 2005 | 06:21 PM
Torque1st's Avatar
Torque1st
Posting Legend
Much easier to install the 400.
Old Jun 16, 2005 | 06:46 PM
Fordbronco69's Avatar
Fordbronco69
Infidel
Im with Torque, you dont have to change anything to put in your other 400...but with the 390 you might run into engine mount, exhaust, tranny-bellhousing problems. And you can do so much more to that 400 to get even more power out of it without breaking ur wallet.
Ide stick with the 400.
Old Jun 16, 2005 | 07:42 PM
ford390gashog's Avatar
ford390gashog
as much as i love the fe's it is not worth while to put it in there just put in the 400 .
Old Jun 16, 2005 | 08:03 PM
docholiday72tx's Avatar
docholiday72tx
As much as I dislike the 351M's and 400's, the other guys are right it's going to be the quickest and easiest.
If money or time weren't just a big issue.....never mind, just put the piece of....I mean 400 in.
Doc
Old Jun 16, 2005 | 10:51 PM
Mil1ion's Avatar
Mil1ion
There is a power build up for the 400.
If it was me, I'd be doing that instead of installing another 160 Hp engine in there.
Old Jun 16, 2005 | 11:50 PM
flcbell's Avatar
flcbell
That settles the argument. The 400 it will be. Thanks a bunch for the input.
Old Jun 16, 2005 | 11:58 PM
Mil1ion's Avatar
Mil1ion
I forgot to add this in the other reply.
http://home.earthlink.net/~bubbaf250/
Old Jun 17, 2005 | 04:48 PM
JohnT's Avatar
JohnT
Smile
Another thing, the 400 will get better gas mileage than the 390. I have a 390 in my 73 F100, and the gas mileage is awful!
Old Jun 17, 2005 | 06:12 PM
docholiday72tx
John, What kind of mileage do you get out of your 390? I had one in my truck for a while and I got 14 MPG out of it. That's not too bad for a 73 model truck.
Doc
Old Jun 24, 2005 | 04:36 PM
JohnT's Avatar
JohnT
Smile
Doc
My 73 F100 2wd with a 390 only gets about 7 MPG. The engine and auto trans. were rebuilt a couple of years before I bought the truck. The previous owner gave me all of the receipts. It runs good and everything, it's just that the gas mileage is really bad. I wish it got 14 MPG like your 73 with a 390 did!
Old Jun 24, 2005 | 10:46 PM
79biggerbronco's Avatar
79biggerbronco
put a 460 in it, it will bolt right in, then you have a real engine, just my 2 cent's.
Old Jun 24, 2005 | 11:41 PM
docholiday72tx
John,
On my 73, It was a 390, 4 speed with 3.00 gears. I hooked up a Ford Duraspark distributor, with an MSD 6A ignition module. I had headers with 2 1/2" exhaust pipes and Flowmaster 50 series mufflers. I run an edelbrock performer manifold with a stock cam, and holley 600.
Doc
Old Jun 27, 2005 | 09:58 AM
bigcrunch2's Avatar
bigcrunch2
the 390 will require different engine mounts, bell housing, PS steering pump mount, ,,, etc,,, the 400 is a good engine however there was an issue with water jacket cracking in the lifter gallery it was a mid seventies issue, look at casting # before investing in rebuild. It was mentioned do a 460, that has my vote, can use same fram perches, use L&L, TD and I think Hooker header makes a conversion maybe only for 4 wheel chassis.
Old Jun 27, 2005 | 01:36 PM
F150daniel's Avatar
F150daniel
His 400 is a 78, they fixed that in 77.
