Serious Ignition Performance
Old Oct 9, 1999 | 09:39 PM
JIM_2's Avatar
JIM_2
I want serious ignition performance on my 90 300/6. I am willing to spend basically anything -$300. What are the best plugs? Wires? I want to replace rotor and cap. Should I use Ford rotor and cap or does somebody else make better rotor and cap? What about the coil?
FORD TRUCKS PERFORM BETTER THAN THE REST.
FORD TRUCKS LAST LONGER THAN THE REST.
FORD TRUCKS ARE BUILT STRONGER THAN THE REST.
DO NOT SETTLE FOR IMITATIONS!
F O R D T R U C K S R U L E!!!
Old Oct 9, 1999 | 11:42 PM
slik's Avatar
slik
I would go with MSD all the way: MSD plug wires, MSD 6A, MSD adjustable timing box, MSD coil; then put in splitfire or platinum plugs; put in the large cap and rotor to help eliminate crossfire. However, some folks like Jacobs better, but whatever you go with, purchase the entire ignition set under the same label.
Slik
Old Oct 10, 1999 | 10:12 AM
Pastmaster's Avatar
Pastmaster
>Slik
slik: I was curious about the MSD ignition coil, does it help even with a factory ignition?
Evan A.K.A. PastMaster
1993 F-150 302/E40d XLT
1989 F-150 302/Aod 4x4 XLT Lariat
Old Oct 10, 1999 | 07:59 PM
slik's Avatar
slik
Hard to say, it's supposed to deliver a hotter spark than the stock coil (more volts) that would give a more efficient burn of the fuel.
Slik
Old Oct 11, 1999 | 09:54 AM
H8monday's Avatar
H8monday
Im affraid you will deffinitely go quite a bit over the $300 dollar mark,if you opt for the MSD set up.The Ignition module alone for an MSD 6AL is about $275.If you go with the Jacobs it should be close to $400 complete.I use the Jacobs in my Jeep and its a very high quality ignition,and produced noticeable improvements in low end torque,which is what i was looking to achieve.In my Ford though I use an MSD set up,"This is a seriouse ignition",but it gets very expensive for a complete set up including,billet distributer,in cab timing controls,etc.The ignition modules can get up to around $700 dollars depending on what you are trying to achieve.I agree that you should stay with a single manufacturer for your set up.Many of the High Performance Gurus,choose to mix and match there set ups using the best components from each manufacturer,but they are,(or should be)very knowledgable on the characteristics of the individual components,and what they are trying to get in terms of performance from each one.The problem with mixing and matching if you arent very familiar with all the components is that you lose some of your ability to use the tech depts of the manufacturers since they wont help you much if you arent using all of there components,it may even void warranties.Later,
Jeff
Old Oct 11, 1999 | 05:29 PM
slik's Avatar
slik
MSD 6A - $131
MSD 6AL - $172 (same as 6A, but with rev limiter)
MSD Blaster Coil - $34
MSD 8.5mm Super Conductor plug wires $59
Splitfire Triple Platinum Plugs $48
MSD adjustable timing control $110
Note: the adjustable timing control is not necessary, just neat!
Slik
Old Oct 11, 1999 | 06:26 PM
H8monday's Avatar
H8monday
Slik,
What motor were those parts for? Ive noticed that the MSD6 have come down in price over the last few months. The prices for my 460 were quite a bit more,I realize a lot of the parts are almost identical from motor to motor.This was about 4 months ago.
7AL2 Ignition $565
8207 Coil $60
8580 Billet Distributer $355
8680 Timing Adjuster $170
Its an expensive set up but with the Kenne Bell Supercharger,a very strong ignition was highly recomended by the Installer.It works great,I have been running Bosch Platinum 4 Spark plugs.
Jeff
Old Oct 12, 1999 | 06:11 AM
slik's Avatar
slik
I didn't price them engine specific; just pulled the prices from my Summit Racing catalog.
Slik
Old Oct 12, 1999 | 01:30 PM
Pastmaster's Avatar
Pastmaster
Slik: Which magazine did you get? The most recent one that I got was the Studebaker on the front. What could I get for a 1989 F-150 302?
Old Oct 12, 1999 | 02:27 PM
slik's Avatar
slik
You can buy all the parts I mentioned for your 302. My son must have the latest Summit, mine is good thru Aug 31st with the Blue Chevy Nova.
Slik
Old Oct 12, 1999 | 08:57 PM
MasterBlaster
Guest
Posts: n/a
