T98 vs NP435
Old Jun 16, 2005 | 04:48 PM
66beater's Avatar
66beater
T98 vs NP435
T98 vs NP435. which is better?
I want a deep 1st gear, and I know the NP435 is a true granny. How does the T98 compare? Will it bolt up to a FE 390?
Old Jun 17, 2005 | 12:16 AM
Fordbronco69's Avatar
Fordbronco69
Infidel
I dont know much about the T98? but....if it has a removable bellhousing then it prolly will bolt up to a 390, with the correct bellhousing.
Old Jun 18, 2005 | 11:08 AM
oldhalftons's Avatar
oldhalftons
t-98 is a good transmission, but it uses the 64-down bolt pattern to mate it to the bellhousing.
Old Jun 30, 2005 | 02:05 PM
66beater's Avatar
66beater
Are there any problems with fitting the older bell housing? will my flywheel and clutch work?
Also, whats the ratio on the t98's granny?
