351W head question
Old Jun 16, 2005 | 11:41 AM
malync2's Avatar
malync2
351W head question
I posted this question on the 351w forum and received a couple of good responses, but I wanted to repost here to see what more people have done. Here's the question:
I am building a 351w on a budget that I hope to make around 350hp. I have access to an engine machine shop so I can do any machine work I want, but I need to keep parts costs to a minimum (ie. no buying high dollar heads). The heads I have are from a 1986 engine, and there are smog holes on the floor of the exhaust ports that I want to get rid of. How is the best way to handle these? I have considered driving (or threading) pins into the holes before grinding the runner smooth, but I am concerned that the pins might come out during use. If this is an option, can I use steel pins, or should I make cast iron pins so expansion rates would be similar? Also, I have seen some epoxy material that is made specifically for reshaping exhaust runners when porting, but I also wonder if it would stay put for prolonged street use. How are others doing this? Thanks. Mark.
Old Jun 16, 2005 | 12:07 PM
Torque1st's Avatar
Torque1st
Posting Legend
Grind it smooth and forget the holes.
Please do not cross post.
Old Jun 16, 2005 | 12:29 PM
baddad457's Avatar
baddad457
Those holes you're referring to are in the port roof, not the floor. And as Torque1st said, just grind the bump flush with the port and forget about the holes. Just make sure you plug the other end of this passage at the end of the head. It's open at one end and has a threaded insert in the other. The open end was to the rear of the engine, the threaded end was up front. You can use either head on either side of the engine, just as long as the front end has the threaded insert and the opposite end is plugged.
Old Jun 17, 2005 | 09:44 AM
malync2's Avatar
malync2
Why is this post in the 351w forum? I had posted this question here earlier, and only received a couple of responses, so I posted it in the performance forum to get additional advice, and now I find it moved. Since when can't I ask a question about a 351w in the performance forum? Please put it back where I posted it. Thanks. Mark.
Old Jun 17, 2005 | 10:21 AM
Kemicalburns's Avatar
Kemicalburns
is this motor carb or efi. the e7's are a better head then those 86 jobers .
Old Jun 17, 2005 | 10:55 AM
malync2's Avatar
malync2
What are e7's? Thanks. Mark.
Old Jun 17, 2005 | 10:57 AM
Kemicalburns
E7's were used on 87 and newer 5.0's and 5.8 engines when they went efi.
Old Jun 17, 2005 | 11:06 AM
malync2's Avatar
malync2
Did they still have the emissions holes? Do they flow better? What makes them better?
Also, for a build like I described, what sort of work should I do to the heads? If I grind on the runners, how much material should I remove? I have been considering going to 1.94/1.60 valve sizes. Should I do that or stay stock size? Thanks. Mark.
Old Jun 17, 2005 | 11:16 AM
malync2's Avatar
malync2
Sorry, I should have mentioned that the engine is carburated.
Old Jun 17, 2005 | 11:18 AM
Kemicalburns
yes the e7's flow better then your current heads stock. add a little port work and some polish on the exhaust side with a 3angle valve job and your set. is this your first time doing this type of work?
Old Jun 17, 2005 | 11:20 AM
malync2's Avatar
malync2
I've build lots of engines, but no experience on windsors. If it were a chevy I'd know which heads and why, but ford info seems harder to come by. Thanks. Mark.
Old Jun 17, 2005 | 02:25 PM
ronclark's Avatar
ronclark
Look on my web site for a howto on porting the windsor heads. http://www.armstrong.edu/ron/auto/e7.html
Old Jun 17, 2005 | 02:57 PM
malync2's Avatar
malync2
That's a great website. Thanks.
