85 ranger head swap
Old Jun 16, 2005 | 02:07 AM
kevin4909's Avatar
kevin4909
85 ranger head swap
I have the 2.8 v6. What heads from other engines would fit my block without major surgery?
Old Jun 18, 2005 | 12:37 PM
TigerDan's Avatar
TigerDan
None, you're pretty much limited to the 2.8 heads. The 2.6 heads should fit, but there would be no reason to swap those on, it's a step backwards for sure! The 2.9 heads will physically bolt on, but that's about all they'll do, as the valve arrangement is different.
BTW, you probably would have gotten an answer sooner if you had posted this question to the V6 forum, this one is more for engine swaps than componant swaps. -TD
