Pyrometer install
Old Jun 15, 2005 | 08:47 PM
John Kiernan's Avatar
John Kiernan
Pyrometer install
Hooked up the third and final guage today (pyrometer). Tapped direct into the drivers side cast iron exhaust manifold. Pretty easy. Most of the shavings fell down and I used a vacume over the hole to suck any remaining shavings out. For safe keeps I took some duct tape wrapped reverse on a piece of coat hanger and picked up any remaining shavings inside.
I am seeing about 800 deg during normal highway driving and when I get on it about 1000 deg. My truck is stock. How do these temps sound ?
Old Jun 15, 2005 | 11:51 PM
111900's Avatar
111900
My stock 6.0L baseline pyro, boost, trans readings
Here's my numbers with a stock 2003 F350 6.0L FX4 dually Crew Cab.
Outside Temp: 55
MPH: 65
Trans Temp: 160
EGT: 600 - 700
Boost: 2 - 4 psi
RPM:
Grade:
Date:
Rig: 2003 F350 6.0L CC dually 8' bed 8100lbs(truck)
Outside Temp: 59
MPH: 52
Trans Temp: 180
EGT: 1050
Boost: 26 psi
RPM:
Grade: short steep hill
Date: 6/4/2005
Rig: 2003 F350 6.0L CC dually 8' bed 8100lbs(truck) + 8000lbs(5th)=16100 GCW
Outside Temp: 62
MPH: 60
Trans Temp: 180
EGT: 1050
Boost: 22 psi
RPM: 1800
Grade: gradual hill
Date: 6/4/2005
Outside Temp: 62
MPH: 60
Trans Temp: 180
EGT: 800
Boost: 4 psi
RPM: 1800
Grade: flat
Date: 6/4/2005
Outside Temp: 62
MPH: 60
Trans Temp: 175
EGT: 700
Boost: 4 psi
RPM: 1900
Grade: flat
Date: 6/4/2005
Outside Temp: 62
MPH: 58
Trans Temp: 170
EGT: 1050
Boost: 26 - 30 psi
RPM:
Grade: hill
Date: 6/4/2005
Outside Temp: 52
MPH: 62
Trans Temp: 160
EGT: 850 - 900
Boost: 10 psi
RPM: 1900 - 2000
Grade: flat
Date: 6/6/2005
Outside Temp: 53
MPH: 58 - 60
Trans Temp: 160
EGT: 1050
Boost: 30 psi
RPM: 2750
Grade: fairly steep but short hill
Date: 6/6/2005
Outside Temp: 53
MPH: 62
Trans Temp: 160
EGT: 800
Boost: 6 psi
RPM: 1900
Grade: slight incline, some flat for about 10 miles
Date: 6/6/2005
Outside Temp: 50
MPH: 65
Trans Temp: 160
EGT: 1000
Boost: 25 psi
RPM: 2000
Grade: hill
Date: 6/6/2005
Old Jun 16, 2005 | 12:35 AM
Hayapower!'s Avatar
Hayapower!
Sounds about right..
My old 03/6.0 S/C S/B 4x4 was running around the same temps.. Of course they were 'strayed' a bit with load, outside temp, elevation/grade, and of course throttle angle if commanded and/or a combination of all of the above..
.....................HP......................
