Modular V10 (6.8l)
Throttle delay
Old Jun 15, 2005 | 10:02 AM
FireInspector's Avatar
FireInspector
Throttle delay
Just wandering if the throttle delay on my new v10 could be adjusted? Recently traded in a 04' F150 that was really bad when purchased but took it to the dealer to see what they could do and somehow they managed to make it about 50% better. I figure a 50% increase in this thing and WATCH OUT! If not a throttle cable conversion that would work with the computer would be great.
Old Jun 16, 2005 | 07:15 AM
FireInspector
hello????????
Old Jun 16, 2005 | 07:23 AM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
Hello... and welcome to FTE.
Because the V10 has a drive-by-wire throttle body, it can't be done, unless there is a recommended flash to fix it.
I am guessing it was a recognised issue with the (also drive-by-wire throttle) F150, and Ford created a new flash for the PCM to fix it.
Generally Ford vehicles with a drive-by-wire throttle have a 10% threshold, whereby you can depress the accelerator, and get no response from the engine.
This is to make it smoother, better emissions and it works better with cruise control.
You can go to the dealer and see if they have a flash for it, but they may not as well.
Old Jun 16, 2005 | 07:32 AM
FireInspector
Thanks BigF350, but does the programmers such as Hypertech or Superchips (when available) deal with this issue? Thanks again
Old Jun 16, 2005 | 07:49 AM
BigF350's Avatar
BigF350
FTE Emeritus
hmmm.... I don't know, might want to ask Ken in the Chips/tuners forum.
I am guessing it wouldn't, but I could be wrong.
Old Jun 16, 2005 | 09:16 AM
FTE Ken's Avatar
FTE Ken
The SCT XCalibrator and XCalibrator2 gets rid of a great deal of the throttle lag.
