Sponsored by: Kumho
Lift help !!???
Old Jun 14, 2005 | 11:33 PM
mattd17's Avatar
mattd17
Lift help !!???
i have a 99 f250 sd, 4x4, 5.4L. i want to get it a little higher than stock, and want bigger tires, but dont want to re-gear. im not sure if i should do a hangar lift up front and switch to the 4" blocks in the rear..... right now, i sit just a little nose down.... and i think the driver side is lower than the pass.... maybe by an inch... i have looked at everything, and im guessing that it is just a tired spring ?? what are yall's opinions? should i put in some new leveling springs, and then go with a bracket also? i think i want 33's, so how high should i go? thanks in advance !!!
