Recall
Old Jun 14, 2005 | 05:21 PM
rmccrory's Avatar
rmccrory
Recall
Does anyone know what the recall is or which F-150 it pertains to?
Old Jun 14, 2005 | 05:43 PM
MommysCrew's Avatar
MommysCrew
SD and excursions and others, but no f150.
Old Jun 14, 2005 | 10:02 PM
MJEmerson's Avatar
MJEmerson
i think its diesel engines only on those models
Old Jun 14, 2005 | 11:58 PM
HankMurphy's Avatar
HankMurphy
The full recall info (except for serial numbers affected) is on the NHTSA site, double-Us dot NHTSA dot GOV - F250s and above are affected, both gas and diesel. There are two recalls - here is the NHTSA text for both:
Make / Models : Model/Build Years:
FORD / F-250 SUPERDUTY 2005
FORD / F-350 SUPERDUTY 2005
FORD / F-450 SUPERDUTY 2005
FORD / F-550 SUPERDUTY 2005
Manufacturer : FORD MOTOR COMPANY
NHTSA CAMPAIGN ID Number : 05V266000 Recall Date : JUN 07, 2005
Component: FUEL SYSTEM, GASOLINEELIVERY:HOSES, LINES/PIPING, AND FITTINGS
Potential Number Of Units Affected : 78675
Summary:
ON CERTAIN PICKUP TRUCKS AND CHASSIS CAB VEHICLES EQUIPPED WITH 5.4L OR 6.8L GASOLINE ENGINES, THE FUEL JUMPER LINE MAY HAVE AN INCORRECT END FORM.
Consequence:
THE FUEL LINE MAY SEPARATE AT THE CONNECTION TO THE MAIN FUEL BUNDLE. IF THE FUEL LINE SEPARATES, AN OPERATOR MAY NOTICE A GASOLINE ODOR AND/OR FUEL ON THE GROUND, LOSS OF POWER, AND THE ENGINE WILL EVENTUALLY STALL. FUEL LEAKAGE IN THE PRESENCE OF AN IGNITION SOURCE COULD RESULT IN A FIRE.
Remedy:
DEALERS WILL INSTALL AN EXTERNAL RETENTION CLIP AT THE FUEL JUMPER LINE TO THE MAIN FUEL BUNDLE CONNECTION. THE RECALL IS EXPECTED TO BEGIN ON JUNE 20, 2005. OWNERS SHOULD CONTACT FORD AT 1-800-392-3673.
Notes:
FORD RECALLNO. 05S33. CUSTOMERS CAN ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION’S AUTO SAFETY HOTLINE AT 1-888-327-4236.
FORD / E350 2004-2005
FORD / E450 2004-2005
FORD / EXCURSION 2004-2005
FORD / F250 SUPERDUTY 2004
FORD / F350 SUPERDUTY 2004
FORD / F450 SUPERDUTY 2004
FORD / F550 SUPERDUTY 2004
NHTSA CAMPAIGN ID Number : 05V270000 Recall Date : JUN 07, 2005
Component: ELECTRICAL SYSTEM:WIRING
Potential Number Of Units Affected : 180104
Summary:
CERTAIN PICKUP TRUCKS, SPORT UTILITY VEHICLES AND VANS EQUIPPED WITH 6.0L DIESEL ENGINES MAY EXPERIENCE STALLING WITHOUT WARNING WHILE DRIVING AND MAY OR MAY NOT RESTART.
Consequence:
SHOULD THE ENGINE STALL, A VEHICLE CRASH COULD OCCUR.
Remedy:
DEALERS WILL UPGRADE THE FUEL INJECTION CONTROL MODULE (FICM) WIRE HARNESS OR REPLACED, AND/OR HAVE A NEW INJECTION CONTROL PRESSURE (ICP)) SENSOR CONNECTOR INSTALLED. THE RECALL IS EXPECTED TO BEGIN ON JULY 5, 2005. OWNERS SHOULD CONTACT FORD AT 1-800-392-3673.
Notes:
FORD RECALL NO. 05S34. CUSTOMERS CAN ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S AUTO SAFETY HOTLINE AT 1-888-327-4236.
So...no F150 recall.
Hank Murphy
2005 XL Work Truck
