Fuze Box
Old Jun 14, 2005 | 02:37 PM
ramtoo's Avatar
ramtoo
Fuze Box
Ok I have a 68 F100 the fuze box under the dash has some non fuzed places that look like spade terminals could hook up there but last time I was under with a meter I got no voltage with the key turned on. Any insites would help looking for places to rob voltage!
Old Jun 15, 2005 | 11:20 AM
rebocardo's Avatar
rebocardo
If you want to rob volatge, the best place would be behind the dash. Remove the dash panel with the speedometer and you should find a three wire connector with female bullet connectors. One will house a connector for the volt meter. Use one of the others to run to a relay.
Power this relay directly from a fused lead from the battery. A through the firewall isolated connector is only $10 from Summit etc. Use that to power the relay. You could use the relay to power a ATO fuse panel and from that run the wires you need.
