Lifter ?.........
Old Jun 14, 2005 | 12:13 PM
460me's Avatar
460me
Lifter ?.........
79 460,new cam and lifters.On the lifter's,Should I let them set in oil or install dry?
Old Jun 14, 2005 | 01:10 PM
53wa2fl's Avatar
53wa2fl
Sit them in oil, while 15 are sitting, take a pushrod and pump one up while in the oil. Install it with some extra cam lube on the bottom, move on to the next.
Kinda like washing your hair...Lather, rinse , repeat......Just repeat 16 times.
Old Jun 15, 2005 | 04:09 PM
460me's Avatar
460me
Will I have a problem setting the lifter preload with them soaked?(pumped up)
I have the shim kit,the heads are also getting done.
Old Jun 15, 2005 | 04:20 PM
greenhighboy's Avatar
greenhighboy
I like doing them dry so that the plunger can move and you can measure the preload. I also do it before putting the intake on so you can see the plunger moving.
Prime the motor with a drill and turn the motor over a few times until you have oil coming out of all the pushrods. Then you know they are primed.
Old Jun 15, 2005 | 04:23 PM
53wa2fl's Avatar
53wa2fl
I havent had a problem with doing it that way yet, but then again, maybe I'm lucky.
Old Jun 15, 2005 | 04:25 PM
460me's Avatar
460me
Thanks.This is the first time doing a complete rebuild.Most of it is just wrench'en,but the lifter and preload is throwing me off a bit
