EFI Upper Intake
Does anyone have one to sell?
Does anyone have a picture of one, on or off the motor?
Two pictures of the upper, with 'things' attached to it.
Here it is flipped down:
not the best pictures... but will give you at least the idea of it's shape. A friend of mine used one of these on a hemi crate motor, making a simple aluminum adaptor from the bottom of the ford 460 upper intake gooseneck, to the carb pad on the hemi's intake. Poor guy did it by hand too... sabre saw, drill press, dremel. But it worked well and allowed him to graft EFI to his 528 hemi crate engine.
The upper intake in the picture looks like it has been modified. It has one or two single barrel TBs mounted on it?
What you see in the pics is the bone-stock gooseneck with other stuff attached to it. Since I'm building a 500cid, twin turbo EFI stroker, I realized quickly that the dual throttle body (as in the above picture) probably won't flow enough, and I wanted the inlets of the throttle bodies to face somewhat outward, at the outlets of the turbochargers. So, I removed the factory throttle body and the bracketry and such, and welded together a bolt-on dual-throttle body adaptor. My first version used GM throttle bodies which you can see in the first three pics of my initial post. I decided not to use GM EFI and learn the Ford EEC system, so I rebuilt my adaptor plenum to use a pair of 4.6L throttle bodies, with a homemade plenum, which looks like this. Since it's a forward facing picture, you can't really see the gooseneck, but it's there.
here's the main project site, if you're interested. I update it occasionally, but I'm much further ahead than the website indicates... I just haven't gotten around to updating it because I've been distracted by too many other things... http://www.midimonkey.com/~frederic/index.html
We have a newborn, I had to cut off and weld in new metal on the crewcab to pass inspection, because I need the truck to pick up gravel and sand for the new patio (which I just finished digging out by hand across several weeks), and the "cut off the rust" project with the crewcab ended up taking forever, not because the rust on the body/bed was bad - it wasn't - but with the truck apart scattered all over the lawn I decided now is a good time to sandblast the frame, seal it, and paint it. And while replacing the rusty front fenders with brand new, freshly painted fenders (which I painted several times because I have to paint outside, and I kept getting pollen in the paint
) I discovered the radiator support was essentially missing, so I had to tear in further, and replace that. Then I accidentially punctured my radiator because I left it on the ground on a piece of wood to protect it's underside, and a large branch decided to fall off for no reason at all, landing on the 2 y/o radiator. Anyway, you get the idea
I replied to your email BTW.
My friend's 528 hemi crate engine now has a 10-72 blower on it. Probably oversized, but now his little vastly stripped down Nova II twists like a pretzel during any kind of acceleration. Yes, you read that correctly, an roots-style supercharged 528 crate engine (with EFI) in a chevy.
it's one of those "I got this engine cheap from a guy who never finished his project" combined with a "This nova has been sitting out back for years unloved, cool, I found the title!" and "hey, a $45 rebuilt torqueflite with no reserve on ebay, 30 miles from the shop" kind of project
