Fitting a front hood
Old Oct 28, 1999 | 09:28 PM
Frank Miranda
Guest
Posts: n/a
can a front end(hood, grill ,quaterpanels)from a 1993f150 fit on a 1990f150 with out too much modifications.
Old Oct 29, 1999 | 11:15 AM
Pastmaster's Avatar
Pastmaster
There is a post a couple of posts down...It should be a perfect fit, except that the wiring is a little different...
Evan A.K.A. PastMaster
1993 F-150 302/E40d XLT
1989 F-150 302/Aod 4x4 XLT Lariat
Old Nov 1, 1999 | 11:47 PM
niteprowler
Guest
Posts: n/a
The swap should work fine but use the rad support from the 93. Also the inner fernder wells may be diffrent.Just fit everthing first and check to make shure all the wiring and engine bay stuff will be secure such as the air box and overflow tank.
Old Nov 2, 1999 | 07:42 AM
slik's Avatar
slik
