Hey my boss just got a new f-450 with a dump body, and when the body is up it has an annoying buzzer. so i thot id unplug it, well i accidently hit a ground with the wire, causing the radio to go out and for it to blow a fuse. but not the radio fuse??? now the radio is dead
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Look under the hood for another fuse box. The later trucks have two or more fuse boxes, and if the circuit is shorted bad enough, it will sometimes blow fuses out of both boxes.
