bed seem rust
Old Jun 13, 2005 | 06:46 PM
ct.russ's Avatar
ct.russ
bed seem rust
i have a 69 short bed that in the bed along the sides is a factory seem that has bubling rust in it .. im not a body man by no meens but im thinking of taking a whire wheel to it ,, some red oxide primer , then some sort of calk but must be able to be paintable ... any sugestions to any of this ??? thanks for a great site everyone
Old Jun 13, 2005 | 07:54 PM
hobo.labo's Avatar
hobo.labo
Your local automotive paint supply should have the seam filler (caulk) you need to fill the seam. Just be sure it's clean and dry. I build trailers in my spare time and use it to seal the seams,works fine. I would suggest you sharpen your caulking skills B-4 attempting it on your vehicle, the next step is paint.
Good Luck, HoBo.LaBo
Old Jun 13, 2005 | 08:51 PM
ct.russ's Avatar
ct.russ
what about the rust ??? and would it be thae same as applying tub calk just not watter based??
Old Jun 14, 2005 | 01:15 AM
71_4x4_390's Avatar
71_4x4_390
I have this too. my truck is in the shop as we speak. My body man said he will have to grind out the rust, weld/brase in metal and grind some more. He regretfully said he cannot say for sure if it will come back in a year, two or five years down the road.... This is one of the dumb engineering designs of the 67-72 trucks.
Make sure you use a sealer that can be painted, silicone sealents will not hold paint.
Old Jun 14, 2005 | 05:24 AM
Greg 79 f150's Avatar
Greg 79 f150
You will need to get out as much rust as you can , clean well, then use a convertor product like Osphos or Picklex 20, then prime it. At that , there is no LONG term guarantee for stopping rust anytime, except metal replacement , and even those have new welds to try to stop rust from forming on. And as said before , get a auto paint supplier type seam sealer that is compatable for your topcoat. good luck. jmo
Old Jun 14, 2005 | 06:29 PM
ct.russ's Avatar
ct.russ
thanks to all the reply'd enjoy the rides... russ
