No make headers with AIR pipe in them?
I live in British Columbia and the emissions testing here is about as strict as California if not tougher. Although they rarely do a visual inspection underhood, technically all factory emissions devices are supposed to be intact and operating.
I thought the AIR or Thermactor system added oxygen which greatly helps the CATs do their job? Anyhow I want to leave it working. If you dont have an Aircare pass here then you cant even insure your vehicle.
I think the fella here was right. Its only the heavy duty 351W, the ones mostly in the F-250-350?, that have the funky AIR plumbing right on the manifolds.
For anyone interested, Hedman headers is the only maker that has headers that will work on the heavy 351W. The headers include the air plumbing pipes. ANd the Hedman light duty 351W headers have the needed EGR pipe bung included so thats what I might get.
Think about what I said in post 10, swapping is probably pretty feasible...there are a few other good options though. I know it sounds intimidating but it might be the best solution if all else doesn't pan out well. It would certainly clean things up under the hood.
Take the plastic fender wells off or move them enough to gain access, it'll help out a lot when working on the headers.
I must of got lucky, all the bolts for my 302's manifolds came right off.
About the bungs, if you can't find something to work, at the very worst you'd have to re-plumb some of the lines with hardware that would work, it's definitely do-able.
I still have a thread going in the 302/351 forum, fully detailed about the 393 project. If you look at the last few posts, you'll see where I am at
Originally Posted by EPNCSU2006
Are you sure the air pipe goes directly into the header? The pipe that runs along the passenger side manifold goes down to the exhaust pipe just before the second cat. converter, and there is another branch of the air hoses that feeds the back of the cylinder heads.
if that pipe that connects between the 2 cats is there to supply fresh air to the 2nd cat (to help it function), then if one was to cut off the 2nd cat, that pipe is then useless.
right?
Originally Posted by Roushians
Which is which? (i need a terminology lesson here)
right?
right?
But if you have modded your exhaust such that the thermactor isn't flowing into the exhaust then it could affect emissions How much ? I dont know. One option though is an aftermarket replacement three -way cat with air(the little tube that sticks out of the cat) Would this do the job as good as the thermactor ?I dunno either...
Originally Posted by MustangGT221
I took a quick look at the fittings on my F-250, they don't look like anything totally special, so I'd say it's possible to weld in new bungs and install those on any header. The work would be a little difficult but definitely possible.
#30
Originally Posted by coplin
For sure. I dont have a F250 but looking at the diagrams of its system I t could be done. Be hard to get it to look nice with all that plumbing though. But then who cares how it looks, as long it goes like hell. Im a fan of sleepers for the street anyhow
