Sponsored by: Auxito
Spare Tire Chafing
Old Jun 13, 2005 | 04:09 PM
2000F-150XLT's Avatar
2000F-150XLT
Spare Tire Chafing
In preperation for a long road trip, Miami back up to NY for a visit, I decided to crank down the spare and check the pressure, etc (I've had the truck since new, and realized I had never even checked the spare
I was shocked to see that the sidewall of the tire was worn down about 1/8-1/4 of an inch where it contacts the frame. Anybody hear of this problem before ?
Before I go buy a new tire, did Ford issue a recall or a TSB on this ?
I'll be sure to use some closed-cell foam padding between the tire and the frame before I crank the new tire up. Thanks.
Old Jun 13, 2005 | 04:20 PM
triton_2002's Avatar
triton_2002
Sorry I don't think ford is gonna give you a new tire. Is the tire actually worn or just indented. I've seen then indented pretty good from the crank being overtightened. If yours was worn down, it was probably a little loose.
Old Jun 18, 2005 | 12:19 PM
Zoltrix's Avatar
Zoltrix
Had that problem with mine, Still holds up though, I dont think mine was worn down that much, but it was not indents. Going on a road trip in 2 weeks, I should check that also, and putting some foam up there is a great suggestion.
Old Jun 18, 2005 | 07:26 PM
fordman311's Avatar
fordman311
As long as it didnt rub through any layers its fine, but if you can look at the indentions and see different layers of the sidewall then need to replace. They are fine to drive on if it's just indented (in my experience). just be sure to put it back in just right, just tighten down til doesnt slide around.
Pushdeck1
May 23, 2024 08:47 PM
pawpaw
1983 - 2012 Ranger & B-Series
76
Jul 6, 2023 02:05 PM
Skalywag
Aug 9, 2015 10:55 AM
gdub
Apr 11, 2014 06:26 PM
PStruwing
Feb 18, 2014 09:06 AM
