On the rear diff cover will be one or more metal tags held on by the cover bolts.
Absent both the tag or the drivers inside door frame sticker with the vin and a BUNCH of codes it is still pretty easy to figure out.
Chock front tire front and rear.
Put key in ignition and turn to run so the auto trans can be shifted to neutral without starting. If Manual tranny Skip the Key crap just shift to "N"
Release park brake.
Jack up and put stands under both sides of rear axle
BE Safe BE Careful!
Mark a chalk line on one tire
Mark the drive shaft so you can see how many times it turns.
With two people see if you have Limited Slip by trying to hold one wheel while turning the other. A open diff will let one wheel turn while opposite wheel is stopped. A LS unit will make both wheels turn same rate.
Get the two chalk marks lined up where you can count the drive shaft turns. One revolution of the wheel will make the drive shaft mark spin by 3.73 or 4.1 or 4.3 times and it is real easy to judge what is 4 minus a little(3.7) or 4 plus a little(4.1) or 4 plus a 1/3 turn(4.3)
Takes longer to jack and brace than do the two tests.
TheYeti... have you met Yeti yet? He can be a mean little bugger but a lot of fun too. Personally I like Monsta better...
