79 Motor mount brackets
Old Jun 13, 2005 | 11:48 AM
chuckprev's Avatar
chuckprev
I have a 1979 F250 supercab 4x2 with a 351W that literally blew up (there was some fire involved). I happened to have a 351M that runs in a derby car. I have a problem however. I can't find any brackets so I can cheaply install the free engine. I have the mounts I just don't have the brackets to mount to the frame. I need to know if I can purchase these anywhere after market or if I will be spending a day at the junk yard pulling an engine for the two mounts? Anyone that can help or has some for sale please feel free to let me know.
Old Jun 13, 2005 | 01:05 PM
Mil1ion's Avatar
Mil1ion
If in fact it is a 351W not another 351M.
You can use the brackets from a 302
Old Jun 13, 2005 | 02:12 PM
chuckprev's Avatar
chuckprev
Yes, the one that blew up was a 351W. The one I will replace it with is a 351M. I have tried to order some brackets to no avail. Seems like they are in the junk yards they just have engines on top of them. So i can use the 300 or 302 to mount the 351M?
Old Jun 13, 2005 | 06:29 PM
oldhalftons's Avatar
oldhalftons
351M, 351W and 302 use the same frame brackets.
300 brackets are the same as the 360/390 brackets, and taller than the 351/302 brackets
The 351M has a different bellhousing pattern than the 351W.
Old Jun 13, 2005 | 06:35 PM
cean's Avatar
cean
79 motor mounts
Please contact me via e-mail.
These might work.
The ones that bolt to the frame. They came out of a 78 Ranchero for a 302. I don't know if they will work for you or not.
Last edited by Mil1ion; Jun 13, 2005 at 07:48 PM. Reason: Removed text & replaced with e-mail mention.
Old Jun 14, 2005 | 04:48 AM
docholiday72tx's Avatar
docholiday72tx
Not trying to be smart, but 302 and 300 brackets are nothing alike. I can provide pictures if needed.
There is one set of brackets that will fit inline 6's and FE's with out P/S.
There is another set of brackets for 302's. You can also bolt a 289, 351W, and I believe a 351C to these brackets.
There is another set of brackets for FE's and inline 6's with or without P.S. This second set of brackets has a slight bend in the driver's side stand to allow for the power steering gear box.
There is another set of brackets for 460 that you can bolt a 429 to also.
I don't have a clue as to what a 351M or 400 use because I don't mess with those engines and prefer not to mess with a truck that they even sit in. The towers I have seen in the bone yards under 351M/400's look a lot like small block stands, and they probably are the exact same thing. How ever, I do not have personal experience to verify this. I would also be concerned with trying to use Ranchero stands in a truck. The Ranchero frame is a whole lot more like a car than it is a truck.
Dennis, If I round up good pictures of the different stands, do you think we could somehow add them up top with tips and tricks or something similar to avoid answering the same questions over and over and to give the swappers out there a visual on what they need?
Doc
Old Jun 14, 2005 | 09:04 AM
chuckprev's Avatar
chuckprev
I decided to just see how the engine fit. Oddly enough the bell housing patterns matched up so perhaps what I thought was a 351W really isn't? Although according to the vin# that is what it is supposed to be. Right now I just consider that lucky. If I leave the current towers in the truck it appears that I will only need a spacer which should be easily fabbed. Thanks for the offer on the ranchero but I know they won't work for me. If the fab works I will post my results.
Old Jun 14, 2005 | 09:13 AM
oldhalftons
Doc
those are only in 67-72's right?
Old Jun 14, 2005 | 10:12 AM
docholiday72tx
Old half tons,
Actualy you can find them in 65's on up. My 73 originaly had a 240 with no P/S and it had the driver's side bracket without the extra bend. I had to change it to add P/S. I don't know what year they quit using the driver's side bracket with out the extra bend, but I know for a fact it was used until 73. The motor stands are interchangeable on the 65 up to 79's as far as 2 wheel drive trucks are concerned. I don't know much about 4 wheel drives. When it comes to 2 wheel drive trucks and motor stands, I've pretty much got it together. I went from a 240 to a 302 to a 390 to a 460 all in the same truck. I do not how ever have much experience with the 351M/400 because I don't have much use for that engine.
There were three 351's used in Fords. 351 windsor, 351 cleveland, and 351M. The only 351 used in 73 to 79 Ford trucks was the 351M. A cleveland was never used in a truck, and the windsor wasn't used until the early 80's. If your VIN number says a 351, then your truck was originaly equipped with a 351M. The 351 C and W both have the small block bell housing patern on the back of the block. The 351W has the big block patern. Measure accross the top 2 bolt holes of the engine that you pulled out, and I'll bet you'll find they are a little 7 inches apart. Before you go to making spacers, you need to find out for sure what you pulled out, and what your putting back in. There should be no need for spacers unless something is wrong. Where is the thermostat housing on both engines? block or intake?
Doc.
Old Jun 14, 2005 | 12:10 PM
chuckprev's Avatar
chuckprev
The engine going into the truck is a 351M that is for sure. The one I pulled out had the thermostat on the intake which, in reading about it, is a 351C? I didn't look at the casting number yet to verify what it is. It was dark and the engine is pretty dirty. It might be obvious that I am new to the 2 wheel Ford truck thing. I haven't delt with the 351 engines before mostly 302s, 289s and 460s. The two top bolt holes from center to center on both blocks are apox. 7" give or take a bean or two. The problem I am having is that the engine mounts that were on the engine that came out of the truck were like a clamp. They bolted to the towers with the bolt going front to back. The 351m mounts have the bolt that bolts through the center of the tower. The towers that are in my truck don't have holes through the center. I would need to drill some but, they appear to not be tall enough.
Old Jun 14, 2005 | 01:46 PM
docholiday72tx
Whoa!!!!! Wait a minute!!! Don't tear up those stands. You probably just pulled out a 460. 460's bolt up to the stands in the manner that your talking about. They are the only motor that bolts up that way. It is defiantely a big block by the bolt spacing. The 7 inches only applies to 351M, 400, 429, and 460. I bet you pulled a 460 out, and your putting a 351M or a 400 back in. Look at the 460 motor stands in my gallery and see if yours look like that.
Check your PM box also.
Doc
Count the intake manifold bolts on the motor you pulled out. It should have 16 bolts.
The engine your going back with will probably have 12.
Also, just for grins, check the VIN number. The 4th digit will be A or J for 460, and H for 351. With motor stands like you say you have, I'm certain you pulled a 460 out.
Last edited by docholiday72tx; Jun 14, 2005 at 02:31 PM. Reason: an easy way to double check the new and old
Old Jun 14, 2005 | 01:49 PM
ecarter50's Avatar
ecarter50
The mounts you describe are for a 460, and the bellhousing pattern is the same on 460, 351m. You need the frame brackets for a 73-79 2wd with 302, 351m, 400.
Old Jun 14, 2005 | 03:25 PM
Mil1ion's Avatar
Mil1ion
This is why I commented on it from the start
Let me guess Vin# letter for engine is H which means 351 in which would normally be the 351M
The E series however could have a 351W since the engine is listed for 78 trucks/Vans
I'll get you pics for the 351M/400 for you.
Old Jun 14, 2005 | 03:32 PM
Mil1ion's Avatar
Mil1ion
460 motor mounts
http://www.clubfte.com/users/mil1ion...otormounts.JPG
351M/400 motor mounts
https://www.ford-trucks.com/user_gal...d=3925&width=0
Old Jun 14, 2005 | 05:45 PM
74 F100 351m's Avatar
74 F100 351m
I thought that 302 and 351m mounts were the same.
